Not exactly.
The Great Cobb AP vs Open Source debate has occurred several times here. I see the need for both, which is why both are doing very well.
Benefits of AP:
1. Plug and play, Caveman with 0 tuning knowledge could do it.
2. Supported by a huge company with a good rep. Simply, you have a problem, givem a call and its taken care of. Same on the vendors end.
3. They have a rather large vendor network. Means products are available, tech support through vendors.
4. Tuning support. Since the AP is a licensed product, vendors stand to make $$$ (and have recourse if something goes wrong) thus more offer tuning/protuning/dyno tuning services with it.
5. Constant updates. More and more functionality and car models are added to the AP all the time.
6. Functionality. It reads codes, resets ecu, flashes maps, real time data/gauges, maps, estimates performance, has a whole slew of other goodies, slices,dices, etc.
7. Lots of dealerships carry it. This helps on the warranty front, because my local dealer is a cobb dealer. If I buy the AP and mods through them and have installed, they will honor my warranty. (SOA may not, but they will I asked)
8. Built in flash safety mechanism and low voltage mechanism. Very hard to ruin your computer.
Cons:
1. Price. Its fixed at $695.
2. Can only use it one 1 car, its "married"
3. Until the new ST comes out, you have to rely on a vendor for a custom map (at $300-$400).
4. no data logging
Total price for a protune (just EM wise) $995-$1095.
Open Source w/ tactrix cable
benefits:
1. Can use on more than one car.
2. Can build as many maps as you want via your lap top.
3. Can data log.
4. Functionality is computer ECU and software limited essentially not harware limited.
5. can get a protune
6. If you own a laptop, it is relatively inexpensive $95.
Cons:
1. Not so easy a caveman can do it. If you improperly save your "rom" file or in the wrong format you are screwed.
2. Supported only by online community or other OS users. No one to scream at, beg for support etc on a corporate level. Basically its on you.
3. No built in low voltage safety or other safetys. You can ruin your comp, it has happened.
4. Requires a laptop. If you don't have one, you are in APV2 territory.
5. Requires multiple programs. one to flash, one to read, do the hokie pokie turn yourself around.
6. Requires you have an inkling on tuning knowledge. If you have no clue how a internal combustion engine operates this option might not be for you.
7. Not licensed so a lot of tuners don't support. A lot of tuners don;t like it not because that can't charge $$$ to tune, but because they assume a lot of liability when tuning with it without recourse. No one to turn to.
Price for protune. $95 (if you own a laptop) + $300 dyno= $395. No laptop = $395+(~$500-~$1000)=$895-$1395 for protune
When to go AP:
--I want instant gratification and don't want to do any tuning research, buy it, plug it in, hit a button, done.
--I want a Cobb vendor in my area to do a protune
--I like the look of cool flashy devices I can mount in cab for display.
Go OS when:
---I want to tune my car, Me.
--I have a laptop and am a computer savy person.
--I can afford to take time to troubleshoot items, this isn't my only car.
--Cobb doesn't make a map relatively close to my application, its gonna take 3 weeks to tune and I can't afford to pay someone $100 a hour to tune it.
--My dyno tuner is not a Cobb vendor.
