Stu_Gotti | 2011 WRX WRB Sedan
Page 1 of 3 123 LastLast
Results 1 to 15 of 42
This is a discussion on Stu_Gotti | 2011 WRX WRB Sedan within the Builds forums, part of the Tech & Modifying & General Repairs category; 2011 Subaru WRX Limited Sedan – World Rally Blue Current State: So my build really just took off in 2016, ...
    U.S. Combat Veteran (3ID) Stu_Gotti's Avatar
    Jan 2011
    Southern Maryland
    Cool Stu_Gotti | IAG Closed Deck (stg2.5) 2011 WRX WRB Sedan
    Current State:
    So my build really just took off in 2016, forcefully so when my stock engine shat the bed... however, with the help of IAG Performance and my car being paid off, we now have liftoff. My plan for this build is to have fun, enjoy the time I do have behind the wheel, and have enormous amounts of fun pushing high levels of boost through this closed deck block and driving it daily.
    Latest baseline was done at IAG and was tuned by Junior. The car put down 427awhp/399awtq on 93 pump @ 21.93 psi. My current limiting factor is the MAP sensor. Omni 4-bar should fix that and is currently on order awaiting delivery. When it's time to retune the car it'll likely have the intake manifold upgraded as well. I think Process West will likely be the IM I go for... it looks superb.
    I'm almost due for tires... I'll likely get the same tire setup as before and see how the new power levels feel on that setup before making wheel/tire changes or any further suspension work like coils or springs.
    Engine/Drivetrain/Fuel:
    ACL Race Main and Rod Bearings
    ACT Heavy Duty Performance Street Disk Clutch
    Aeromotive A1000-6 Fuel Pressure Regulator w/Fragola Fuel Pressure Gauge
    ARP Head Studs
    Blouch Dominator 2.5XTR 10cm Exhaust
    Cobb AccessPort
    Cobb Downpipe
    Grimmspeed 3-Port Electronic Boost Control Solenoid
    Grimmspeed 38mm V-Band EWG Up Pipe Black Coated
    Grimmspeed Turbo Heat Shield
    IAG 3mm Phenolic Spacer
    IAG Air Pump Block Off Plates
    IAG AOS
    IAG Braided Race Fuel Lines and Fittings
    IAG Spec Steel H-Tuff Connecting Rods
    IAG Stage 2.5 Closed Deck Short Block
    IAG Top Feed TGV Deletes
    IAG v2 Top Feed Fuel Rails
    ID1000 Fuel Injectors
    Kartboy Long Exhaust Hangers
    Killer B Motorsports Ultimate Oil Pickup
    KS Tech 73mm MegaMAF Intake
    Manley Platinum Series Pistons
    Nameless Axleback
    Nameless Midpipe
    NGK Iridium Spark Plugs +1 Step Colder
    Omni 4-Bar MAP Sensor (Awaiting Install + Tune)
    Perrin Front Mount Intercooler
    Perrin EL Header
    Perrin Turbo Inlet Hose Red
    PST Carbon Fiber Driveshaft
    SPT Short Throw Shifter
    Tial 38mm MVS Wastegate
    Turbosmart Kompact BPV
    Walbro 255LPH Fuel Pump
    Wheels:
    18x9.5 +40 Gunmetal Rota D by Mach V
    Tires:
    265/35ZR-18 Michelin Pilot Sport A/S 3 from Discount Tire Direct
    Brake System:
    2007 Subaru WRX 4/2 Pot Conversion - Refurbished and painted with G2 Caliper Paint Kit (Black with White Letters)
    DBA T3 ClubSpec 4000 series rotors (front & rear)
    Hawk HPS 5.0 pads (front & rear)
    Goodridge Phantom SS brake lines for 08+ STi
    GS Master Cylinder Brace
    Conversion Caliper Bracket V2.0
    Suspension:
    Left & Right STi Group-N Engine Mounts from Rally Sport Direct
    Kartboy Pitch Stop from Rally Sport Direct
    Kartboy Front & Rear Shifter Bushings
    Whiteline 24mm Front Sway Bar
    Whiteline 22mm Rear Sway Bars
    Kartboy Front & Rear Endlinks
    Kartboy Positive Shift Kit from Rally Sport Direct
    Group N Transmission Mount
    Interior/Exterior Enhancements:
    SMY Dual Gauge Cluster
    SOLiD Vent Pod
    52mm Prosport Boost Gauge
    52mm Prosport Oil Pressure Gauge
    52mm AEM Wideband UEGO Gauge
    Kartboy Shift Knob (Black Aluminum)
    Grimm Speed Plate Relocate from Rally Sport Direct
    Rally Armor Flaps (Blue Letters)
    ProClip
    Yakima Roof Rack + Fairing -or- LoadWarrior Basket
    35% Tint
    Fully Sound Dead
    Prova Blue Rear-view Mirror from Rally Sport Direct
    Plasti-Dip'd Fog Housing & Window Chrome
    WeatherTech Front, Rear, and Cargo Floor Liners
    Extended Arm Rest
    Hella Optilux Extreme XY Yellow Bulbs for Fog Lights
    Trunk Cargo Netting
    Shorty Antenna
    Perrin Red Radiator Shroud
    Perrin Red Belt Shroud
    Blacked Out WRX Side Markers
    Pioneer AppRadio 4 SPH-DA120 6.2-Inch Capacitive Touchscreen Smartphone Receiver Display (Planning)
    Before removal of plastic strip atop bottom bumper opening...
    After...
    My Build : IAG Closed Deck Stage 2.5 ~ 427hp/399tq | Facebook | I may appear calm, but in my head I've killed you three times
    Palmyra, NJ
    In for pics!
    Love that silhouette pic though.
    Registered User Rondizzle's Avatar
    Sep 2013
    Southern California
    Pics please!!
    Jan 2011
    Southern Maryland
    Going to get some pics up shortly, knocking out some of my homework while I have some time..
    Registered User brucewayne's Avatar
    Mar 2014
    sayre, pa
    Nice list you have there!
    2014 DGM Sedan
    Stink Eye Mob #228
    Jan 2011
    Southern Maryland
    Updated 1st post with pics taken earlier today and some older ones at the end.
    The Jedi Ninja TownLine500's Avatar
    Oct 2013
    Boston
    Nice car!
    Picks are great, can't wait to see where you go next.
    STINK EYE MOB #500
    2009 Subaru Impreza (I bought it new for my Mom)
    2004 Subaru WRX (Sold)
    2013 Subaru WRX Premium
    1996 Honda Civic Lx
    WRX genuine Face Ripping ACCELERATION!!!
    My Boston Beat Down Build Thread
    http://www.clubwrx.net/forums/builds...wrx-build.html
    Palmyra, NJ
    Ugh I can't wait to get my PW TMIC on.
    Jan 2011
    Southern Maryland
    I still have some tiny bird feathers I need to clean off there... hood got hungry one morning. Love the TMIC, makes opening the hood even better.
    Registered User Goose42's Avatar
    Jun 2014
    PNW
    Nice shots man!
    Or he is rolling down the street in his new slammed ride vaping out the window, enjoying the tow truck ride. - XJman
    2017 ISM Impreza 5MT Hatchback Sport
    2015 WRX COBB Surgeline Stage 2 Pro Tune (Sold)
    Journal-
    http://www.clubwrx.net/forums/builds...ml#post3579257
    Jan 2011
    Southern Maryland
    Quote Originally Posted by Goose42 View Post
    Nice shots man!
    Thank you!
    Jan 2011
    Southern Maryland
    Been a while but scooped up some stuff for comfort/protection recently:
    Extended Arm Rest
    Trunk Cargo Netting
    Plan on picking up a set of used 4/2 pots from a local Subaru guy and building those out in preparation for more power.
    Going to head out sometime over the week or next weekend for updated pictures to refresh the thread.
    Jan 2011
    Southern Maryland
    Still no pics, but more stuff on order: Grimmspeed 38mm V-Band EWG Up Pipe, black coated, blue Tial MVS Wastegate, WG bracket, Walbro 255LPH Fuel Pump, and Grimmspeed 3-Port Electronic Boost Control Solenoid
    Palmyra, NJ
    Convenient, I'm also looking for some 4/2 pots!
    Jan 2011
    Southern Maryland
    I'm excited to see how this all turns out. Lots of crap to install once school is out.
