Should you let your car warm up in the winter?
1 reading
19K views 47 replies 22 participants last post by  SugarMouth
#1 ·
WRX owner here. Would like to see what your guys thoughts are on letting your car warm up in cold weather. Hearing both do it and not to do it. For me. When it's 8 degrees in the morning I like to warm my car up for at least 5-10 minutes before heading off to work. My WRX doesn't seem to like it if you don't let it warm up. I feel as if taking off in the car without warming the engine would hurt the car. Us WRX owners have the flat engine which needs a minute to run for the oil to get through the system. Also have heard proper warming of the car has good effects on making the turbo last longer. What are yours guys thoughts on this?
#2 ·
For the sake of my comfort I'll warm my car up a few minutes. Just remember when your oil is super cold it doesn't flow properly and idling makes that oil take longer to get to the proper operating temp to lubricate.
Sent from my Nexus 6 using Tapatalk
#5 ·
I get in car
Turn key on
Wait for needle sweep
Hear fuel pump
Start car
Put seat belt on
Tune radio to am station
Turn seat heater on
Get on the road
I keep it under 3k till 175 F on the trans oil
#15 ·
This is almost exactly me too...........
If there were some "limits" as to how hot the oil had to be, or how cold is too cold to drive, or time-of-warmups, that need to be followed for this car, they would be in the owner's manual. The only thing in the manual is this:
"NOTE
. Avoid rapid racing and rapid acceleration
immediately after the engine
has started.
. For a short time after the engine has
started, the engine speed is kept high.
When the warm-up is completed, the
engine speed lowers automatically.
. On rare occasions, it may be d"
Note that the first bullet is assuming you start driving immediately after start! It says to not do rapid accelerations immediately after start; it does not say 'don't drive until so many minutes after start.'
#12 ·
Sometimes. All depends on how late i am :cool: Now that I got this frost thingy for my windshield from the Mrs mom for christmas, i've been extra slacking.. Usually i'll let it sit for 5 minutes ish, just because my drive is just over a mile... Otherwise the car will never warm up. My idle drops at 107.6. lol
#16 ·
I start it up, listen to it run for a few seconds (old habit from a time when I needed to make sure my engine sounded "right" before going anywhere), then drive VERY gently through my neighborhood, at which time the needle is beginning to move. I keep revs under ~3000rpms until the needle has cleared the first mark.
Unless it's somewhat colder, like this morning. I let it run in the garage, and get the seat nice and warm, before I hopped in and took off. ;)
#20 ·
Pretty much this.
#19 ·
Try lectures on MP3. There are entire courses freely available on YouTube for example. Anyway, I don't warm the car up. I drive the car mellow not only because that's what the manual says, but also because I live near other humans that may still be asleep. By the time I'm on the main road the car is warm. Done.
#24 ·
I know they say modern cars don't need to be warmed up in the morning but.......I turn the ignition on, wait for car to cycle, start it up and let it idle till AP says coolant temp is at 100 degrees and drive off. I keep it below 3K rpm till the engine is up to temp.
#25 ·
I turn the key to acc, let the pump prime, then fire it up. I let the car idle until the oil temp is ~105 as read by the AP(idle drops around this time as well), then drive gently until oil temp is around 180.
#28 ·
I always let the car idle for 1 minute before pulling away. The first 30 seconds contributes to the highest engine wear.
Engine speed not to exceed 3000 rpm before coolant is fully warm
Engine speed not to exceed 4000 rpm before oil is fully warm.
It's a moot point anyway since I rarely exceed 3000rpm anyway.
Sent from my SAMSUNG-SM-G890A using Tapatalk
#36 ·
Good grief, really?
I suppose I used to be easier on my cars...my BRZ (and my bugeye when I owned it) sees 5-6000rpms, daily. Some day I'll be dead.
#30 ·
I Always warm up the car. both of our cars have remote start buttons. so i can turn it on while enjoying my coffee before work. when i got outside? the engine temp is just below regular running temp, the exhaust note sounds right, and the inside of the car is toasty warm.
BTW: @XJman, -5 to-20 degrees Celsius on my island, no Dramas with the oil on cold starts. actually starts better than our Leggy with lower mileage and thinner oil.
#31 ·
Rule of thumb: oil takes 2x longer to reach operating temperature compared to coolant.
#39 ·
For what its worth I let it warm up for about a minute, then accelerate gently until the temp gauge has been in the normal range for a at least a few minutes.
Near or below zero degrees F more warm up and even less demand on the right pedal.
#44 ·
Yesterday the lowest overnight temperature in my area was around 5°. My garage is not heated. I was pouring some Rotella 15W-40 (a great oil, at a terrific price BTW) into an engine and by that time it must have been around 10°-15°, no more. The oil was visibly viscous and poured very differently to the way I'd expected.
I think Subaru and everyone else are right to go as "thin" as possible. Not only does this save fuel over the entire fleet but it seems to allow better cold pumping, plus it seems to transfer heat during use better than the more viscous oils of yesteryear. For my particular applications a 15W-40 HD diesel oil is fine, but any colder (say, below 0° overnight) and I really do suspect a 5W-40 synth would have provided better cold startup flow.
That said, I only warm up carburreted engines because I have to. If it's fuel injected I'm driving away in it.
