2002 Silver WRX Sedan
Interior Mods
- Subaru red hazard button
- Sparco Street Champion wheel
- SMYClustermaker cluster pod, AutoMeter a-pillar pod, Kakumei carbon clock replacement pod
- KYOUU New Zealand seat rail mount plates
- BuddyClub seat sliders
- Bride Gias Kevlar/Carbon seats
- Sparco/Schroth IMSA approved 4pt harnesses and mounting hardware
- STi OEM floormats
- Momo Aluminum floormat savers
- AutoSpeed dead pedal
- Alfa ProDrive replica gauge faces w/ blue EL lighting
- STi OEM 'Ti' shifter bezel and carbon shift pattern decal
- Sparco Clubman leather shifter gaiter
- AutoBahn Kraftwerks 420gm carbon ball shift knob (see 'Transmission/Drivetrain')
- Kakumei Cheetah carbon brake lever cover
- MR V2 EL gauges - electronic sender series version 2
- NR-G Innovations harness bar/N brace (see 'Suspension')
- Pioneer/Premier 'SPL Champion - Limited - Signature Reference' sound system 4000/50x4wrms - 4200wrms - see pics
Exterior Mods
- ChargeSpeed D1 version front bumper
- ChargeSpeed D1 front brake ducts
- ChargeSpeed D1 20mm wider front fenders w/ functional brake duct exhaust vents
- Kakumei spoiler riser (ProDrive Style)
- Kakumei spoiler multiplier / lower deck spoiler (Mines' Style)
- Motegi Rotary Forged/Heat Treated FF 18x8 rimset w/ 245zr40x18 Falken 912 tires
- Muteki Forged Lugs
- Eagle Forged Studs
- Morette Dichroic Ellipsoid HID headlamps - Hella 50w ballasts / Osram 4200k
- Hella MicroDE Dichroic Ellipsoid HID driving lamps - Hella 50w ballasts / Osram 4200k
- GrillCraft center grill
- JDM Subaru OEM WRX 3" scoop - vacuum moulded
- Kakumei WRC forward hood louver/vent - vacuum moulded
- Hella Supertone horns - Bosch 40a relay/ 35a fuse - Momo track button guts
- ChargeSpeed brake ducts - vacuum moulded
- Subaru 'OEM' 8" wide WRC sideskirts - reshaped for USDM standard Impreza door cutouts - vacuum moulded
- BMW sharkfin multiplexing roof mount antenna - vacuum moulded
- Door handle bezels vacuum moulded
- trunk lock delete w/ solenoid and OEM remote access
- debadged
- WRC tribute badge decals
- Sparco door knock plates
- OEM JDM clear corner lamps
- GrimmSpeed a-pillar antenna delete plate
- underbody fully sanded, gold-coated 4x layers
- JDM STi rear fender flares
- JDM STi rear bumper caps
- Cusco vortex generator - vacuum moulded
- ZeroSports OEM replacement tow ring
Engine
- Ralco crank pulley OEM diameters
- Unorthodox power steering pump hub adapter
- OBX custom cut 15% underdrive power steering pulley
- BushWacker Australia 10% overdrive alternator pulley
- Gates Racing 'RB' Series belts throughout
- ported/polished throttle body assembly
- Samco hose kits throughout
- MagnaFlow T bolt clamps throughout
- Weapon*R and GBA Australia reservoirs and tanks
- StreetWires 1/0AWG power and ground wire and hardware
- Optima Red/Yellow dual battery system 2100CA
- SoundStream 2FD digital hard capacitor
- Apex'i/Weapon*R/ChargeSpeed modified short ram cold air intake system
- 2010 JDM STi Intercooler
- Greddy RZ BPV with 'hotpipe' kit
- Mishimoto hard upper rad pipe kit
- Samco rad hose kit lower section w/ Greddy temp sensor
- Greddy oil filter sender adapter
- Summit Racing braided stainless remote oil filter sender lines - 18" x 2 w/ NPT caps pre-installed at factory
- Hallman RX Pro Ceramic remote manual boost controller
- GrimmSpeed 3 port boost solenoid
- Forced Performance 'FPGreen HTA' journal bearing compressor assembly
- JDM STi 'Pink' 565cc injector set
- 91o tune - 305awhp/320awtq @ 31mpg hwy/24cty by Caron's
Transmission
- ACT StreetLight Flywheel
- ACT HDSS3 Clutch
- PPG anglecut gearset
- treated r160 rear diff.
- DSS rear axles/DS
- Eagle hubs
- GoodRidge Stainless clutch line
- Subaru Super S 90
- see 'Suspension/Steering' for braces
Exhaust
- DC Sports stainless 4-2-1 UEL header/manifold
- Helix catless up-pipe
- Apex'i Sport Ti 4" Bellmouth IG downpipe
- Bosch 3200F EGT probe
- ZoomSpeed 4"-3" stainless resonated midpipe
- Borla 'Hush' stainless steel axle back exhaust system
Suspension/Steering
- Fully seam welded frame and flex-seam welded interior skin, filled and seam welded 2005 WRX/WRC rear differential cradle
- KW Variant 3 - 64 way adjustable coil-over gas-oil suspension system
- Subaru front upper strut mount spherical bearings
- RCE front helper springs ("Black")
- Group-N front and rear upper strut mounts
- Hotchkis front and rear camber bolts
- Cusco pillowball adjustable length rear trailing arms
- Massive Race Spec adjustable rear and front rear control arms
- STi Group N Forged front lower control "A" arms
- Turn In Concepts trailing arm bushings - street durometer
- Deep-Freeze treated rear axles
- Deep-Freeze treated driveshaft
- Eagle hardened front CV/axle assemblies
- Stance billet transmission mounts
- Cusco "T" chassis braces
- Cusco "R" trunk brace
- Cusco "V" brace
- Cusco "B" rear upper strut brace
- Cusco "A" front upper strut brace
- Cusco "M" rear swaybar mount brace
- NR-G "N" brace
- Paranoid Fabrications "I" front fender cowl braces
- Whiteline "HD Forged" rear sway bar mounts and bushings
- STi alloy front lower control arms
- Perrin Positive Steering Response System (Street)
- SPT "H" center chassis brace
- Perrin Cross-Lock polygonal aluminum front subframe replacement
- IIR 34mm solid rear 3 way adjustable sway bar - track stiffness
- IIR 32mm solid front 2 way adjustable sway bar - track stiffness
- IIR billet pillowball front endlinks
- Hotchkis billet adjustable pillow ball rear end links
- GTSpec rear subframe dog-bone brace and bushings
- Kartboy rear subframe lockdown bolts and collars
- WhiteLine rear differential bushings
- WhiteLine rear subframe bushings
- Whiteline rear outrigger bushings
- Whiteline steering rack bushings
Braking
- StopTech Drill/Slot heat-treated rotors front/rear
- GoodRidge stainless brake lines front/rear
- Hawk HPS brake pads front/rear
- Cusco brake master cylinder brace
- Motul RBF Synthetic brake fluid
http://s248.photobucket.com/user/tasmancrawford/media/photo4_zps6d5abaad.jpg.html
coming soon:
ETS TMIC
APS turbine inlet and intake pipes
new TGV deletes w/ servo plates
(I have a pressure drop issue this will cure)
and...
new pics!
