Ticking noise only heard under very light throttle
1 reading
52K views 17 replies 11 participants last post by  Darin Scott
#1 ·
Still have this problem :confused:.
The car is a 2002 WRX with 90k miles, bone stock.
The noise could be described as "ticking" I suppose. It is comign from the front of the car, although I can't tell if it's the engine or tranny. It only does it ABOVE 3000 RPM (loudest over 3500 RPM), only does it in 1st, 2nd, and 3rd gear (although very very quiet in 3rd), and it only does it when I apply VERY light throttle. By light throttle I mean just enough to keep a constant speed. If I let off the gas, or apply more throttle to accelerate quickly, the sound stops. I can also hear it when I shift, for just a split second as I let off the gas, just before I left off completely when I'm still applying "light" throttle, if that makes any sense.
I've had this sound for some time now, and it doesn't seem to be causing any problems, but it's just not normal. It also might be worth mentioning that I have a bad O2 sensor atm, although I'm not so sure that could have anything to do with it.
Any help would be appreciated, I just want to finally get rid of this annoying noise.
Thanks ;)
#2 ·
90k service replaces the timing belt
was that done?
#6 ·
Sounds normal for my car... It's been doing it for ever, It's annoying for sure but I just ignore it and car now has over 167,500 miles and still going strong.
#9 ·
5w-30 is too light for a motor with nearly 90k miles. Fact of the matter is, with 90k miles the motor is looser than it was stock, so now it's noisy. Nothing is broken, persay, but all the little ticks and groans and creeks and bumps are going to sound louder because you're basically using water for motor oil. Temperature permitting, try stepping up to a 10w-40 or a 15w-50 (in the summer). I personally run 10w-40 in my STi with 75k miles on it but will probably go thicker for the warm weather. I let my car warm up about 3-4 minutes every time I start it cold (in the morning, after sitting more than 6 hours, etc). Just a little extra something in there to help quiet everything down and give some extra cushion on critical engine parts.
#10 · (Edited)
Do you really think 10w-40 would be feasible for sub zero temperatures though? Winters in NH can get pretty brutal, I've always been told that 5w-30 is best for our winters and anything heavier would be risking cold start damage. The problem was there in the summer/fall too, but I was using 5w-30 then as well. I'll try 10w-40 and see if it helps at all, but do you think I should wait until spring time? Temp is still getting down into the teens and 20s every night....
Thanks for the responses, it's nice to finally get some useful suggestions. I've asked numerous people/forums about this, and half the time I get "lol tighten heatshieldz noob" and the other half people just have no ideas.
#12 ·
Hate to be a downer or an alarmist but I think you spun a bearing... actually I all but guarantee it. For about 2-3 months when I would first start the car it almost sounded like crickets in the engine bay. Once the car warmed up...it would go away.
Then about a month ago I started getting a ticking noise at low RPM and - 25% throttle. Most specifically the noise came from somewhere on the drivers side, just under/in front of the intake manny.
The tick eventually turned into a clank. It got louder and louder and oscillates at the same rev as the engine, but mostly at extremely light throttle in lower gears. At this point it was just extremely embarrassing to drive it was so loud and crazy sounding. Like a golf ball in a coffee can.
Then, on my way to work last Monday, the rod shattered and the engine seized while I was going 30 mph down the road. :whoa:
drum roll......the new engine will be here Thursday :(.
I seriously hope I'm wrong but it sounds to a tee my exact situation...I too have 90k on the car.
#13 ·
It's not a spun bearing. A spun bearing is way more than just "oh hey what's that noise?" A spun bearing is, "help my motor won't start, won't idle well, drives like garbage, AND has a ticking sound."
And no, you shouldn't use a 5w oil in sub zero temps. I didn't realize you were in NH...I'm in FL so it's not a big deal. Wait till it gets no colder than 20 degrees before you go heavier weight.
~Tim
#14 · (Edited)
~Tim
That's after it has damaged the internals, it's progressive damge...you can drive with a spun bearing for 15k miles if you don't ever stress it too much. You said yourself: "with 90k miles the motor is looser than it was stock" . That's how bearings get spun, too much movement inside the block.
Again, I hope it isn't, but the EXACT same scenario he describes just happened to me less than 10 days ago.
Low oil is not going to make that noise that oscillates at the same speed as the engine...but whatever.
Just dump heavier weight oil in there so you can't hear it and everything will be ok :rolleyes: Pretty sure used car salesman use the same tactics so good luck with that. I suggest you pay the $88 and take it to a dealership for diagnostics so you don't do anymore, irreparable damage "thinking" it's one thing when it's actually another.
So your in FL Tim? Have you been to any of the AWD meets we've had lately? www.floridasubarus.com you should stop by!
#15 ·
OK - this is a big departure from what the other, more experienced guys have mentionen, but here's my $.02
Turbo Wastegate.
The RPM range is right where the Turbo starts spooling on the 2.0L (I think)
WOT makes it go away
No Throttle makes it go away.
Sound disappears at higher and lower revs (when Wastegate is not in flux)
sounds very similar to what I here on my slightly used '07 (though at a different rev-points)
One other thought - when I first got my car, it sounded really loud, and I was very frustrated - until one day I was checking my tranny fluid and noticed there was a rubber buching on one of the wires as it goes through the firewall that was missing. I found that it had come out of the hole, and slid up the wire a few inches.
I slid it back down, popped it in the hole, and the volume of the sound decreased by 85%. Barely noticeable now, I am sure I am the only one who's in my car that ever hears it.
The only thing wrong with my thoery is that 4th and 5th are unaffected for you... hmm... I dunno, I guess just one more thing to think about.
#18 ·
My 2003 wrx has that same problem, it only occurs at cruising speeds and stops as soon as I either give it more throttle or let off the throttle. It has over 200k and has been doing it for at least the last 20k. Changed TB, but still does it. It also doesn't pull much anymore in 2nd although it shows full boost on the gauge. Shes a bit tired but still running. I fixed it by buying a newer one and gave the 03 to my girlfriend to drive.
