Rough idle
3.2K views 4 replies 2 participants last post by  20garcia01
#1 ·
Hey so my 2014 wrx has been having a problem with a rough idle. It idles completely fine on cold starts and everything is normal but once it warms up it starts to idle bad like it’s misfiring. I’ve read the codes on the car and it’s a p0113, and a p0102. I’ve cleaned the maf sensor thoroughly and it has helped a little with the idle but it’s still the same. I have no vacuum leaks I’ve triple checked all the hoses and everything seems to look good. I’m completely stumped and have no idea where to look now and what to do. I also have a p0500 code but not sure if that has anything to do with it.
#2 ·
p0113 has to do with Intake Air Temperature, and that the temp on the sensor is too high.
p0102 has to do with the MAF sensor and all that jazz. since you cleaned out the MAF sensor I assume you know that.
p0500 has to do with vehicle speed obv.
I'm gonna go out on a limb here and ask:
is it stock? 99% of the issues I've seen on here that pertains to rough idles/misfires for the 08-14 WRXs tend to lean onto the side of having a long list of parts and no tune. I've also seen more people turn their engine into a knock-knock joke while using open-source tunes versus pro-tunes.
Remember, if the "cold air intake" (like perrin's) is heatsoaking in the engine bay, it's going to be sucking up all the air from around it, inside the engine bay, and we all know how hot the 08-14 gets. I'll put a dollar on that being what's throwing your p0113.
Without a tune and with an aftermarket intake, you're changing the airflow volume coming into your engine, versus what it's tuned for (assumptively), which would cause it to misfire. The MAF sensor would need to be re-mapped for that. There's code p0102.
p0500 could be a few other things, but I haven't seen anything about that yet so I'd love to see if that is also a possible code thrown by what I've previously said.
If neither of those boxes apply, I'd check the fuel and make sure it's a good mix. If you don't have it tuned and you are running aftermarket parts, I highly, highly, highly recommend getting it tuned (as soon as you can) at a place that knows what they're doing. I've seen way too many people blow their engines on open-source tunes done in their backyards.
I'm in the same boat right now. I've got the money saved for the parts and tune but we'll have to see what this gov shutdown is gonna do before I blow my savings and possibly be out of work for however long :')
#3 ·
The car is 100 percent stock. I haven’t done much to the car other than maintenance, when I cleaned out the maf it had helped a bit, but it still idles rough. At this point I’m thinking it’s some kind of leak somewhere but at wot it runs and pulls completely fine no boost cut off nothing, other than once I come to a stop it idles really bad almost like it wants to die but it hasn’t died on me yet. Is there a specific place where I should be looking at for some type of leak?
