Question: Sti v7 springs and v8 struts
1 reading
1.6K views 3 replies 3 participants last post by  Big Sky WRX
#1 ·
I have v8 sti usdm struts with tophats
Will the v7 sti springs fit these struts? Guy i'm buying them from says it will fit but i dunno if i believe him.
help mee = )
#2 ·
I believe so. You'll need v7 (US 02-03) tophats out back.
#4 ·
If I understand you coorrectly- you have v8 struts and v8 tops and you want to fit v7 springs. The answer is no they won't fit w/o some rear v7 tops. The v8 tops won't accept the v7 springs. The v8 top is designed to accept the tapered v8 spring.
If you can get a set of rear (fronts will fit no problem) v7 tops- your good to go.
Curious how you ended up w/ v8 struts and tops w/ no v8 springs?
You can source used v8 springs all day long from the STi guys. Maybe your looking at the v7 RA springs- which if that's the case- good choice. If they're regular v7 springs pass on them and get v8's.
Big Sky
