I have a 2002 WRX. When I got it, I put an AEM cool air intake in as well as a turboX blow off valve. Besides that it's stock. The Turbo was replaced not too long ago as well. The car has 93k miles. For some reason yet to be determined, the car has no power above 4.5k RPM's. It wants to and you can feel it trying to but it doesn';t happen. If you are just cruising up to 45MPH and shifting before 3.5-4k RPM's I guess you couldn't even sense anything was wrong with the car. The blow off valve is making the noise and releasing the air and it sounds fine, however, when you try and drive it like it should be driven, something is not right. If you tried to go from 0-60MPH it would take you much longer then it should.
My mechanic has tried replacing the blow off valve and the intake with the stock parts and that didn't work. They have taken parts out and checked them too...
Could it be the computer? What should I do? Anyone ever experience this or have any idea what could be the problem?
