jdm vs usdm
1 reading
9.7K views 14 replies 10 participants last post by  Shard
#1 ·
what is the differences in the jdm wrx and the usdm wrx? motor, drive tran and Exterior?
#3 ·
Yup catless up pipe...
Only your STI gets a differnt motor... Drivetrain is the same...
We get the subaru four pots standard, as well as the nice bucket seats... Alloy Hood... 182 Kw (250hp)... 17" alloys... alloy front arms (sedan only)... HID lights...
#7 ·
I thought yours had been raised also???
Down here the NZDM and ADM are both 9.0:1 just like JDM and both our domestic market WRXs are only rated at 160kw... (220hpish) compared to 182kw (250hp) JDM
They detune the ecus cause of our petrol... Less aggressive fuel map, compared with the JDM
#9 ·
Thats not a bad thing... The latest REXs are a lttle tough to tune for the reason that the compression causes early det, unless you spend dollars on fuelpump, injectors, UTEK etc... whereas my oldschool 8.0:1 just loves a tickle everynow and again...
It has seen 1.51 bar on original STI standard motor... Thats on Race gas mind you, but still didnt miss a beat!
Cant say the same for CRAPPY JEs!!!!! couldnt even handle 1 bar for 1500miles! Yup im bitter!:D Dont buy them EVAR!!!!!!!!!!!!!
#10 ·
#14 ·
and u get avcs on the base wrx, its just a ej20 in a higher state of tune, less cats, higher compression, diff ecu, diff heads...but still the same basic design
