Hi, I purchased a 06 wrx about 2 months ago and it has run great up until now. I live in Michigan and it's getting cold out so I'm wondering if temp has a decently significant effect on wrx's.
I assume by warm up you mean letting it idle, but that isn't going to help your gear box warm up.Your gear box will be harder at first, as the fluids get thicker with cooler temps. A 5 minute warm up is a good rule of thumb
A block heater in VA? Are you kidding me? :screwy:my 06 doesn't like real cold weather either. it can take another few seconds of cranking before it fires up. when I noticed it, i put a block heater on mine. may be overkill where I am in VA but it still gets cold out here and it seems to start a little quicker after i've had the block heater plugged in. hasn't gotten cold enough this year to start using mine yet. I installed mine myself and it only cost me $30 + a gallon of new subaru coolant and distilled water to mix it with.
Your turbo is designed to operate at very high temps, so the colder it is, the less efficiently it operates. That's why turbos have heat shields on them, to keep them HOT! Once your car is fully warmed up the turbo and the car in general should feel as good if not better than in warmer weather.in response to both of you, starting is good so far, but i guess the best way of describing my problem is that all summer my powerband was real smooth and at around 3,000 my turbo would kick in and throw me back in my seat. now that its cold it seems like my power cuts out at 3,000-3,500 then my turbo hits. I guess it just seems like my turbo isnt spooling up as quickly or something because i have really peaky power now.
