White Smoke at start-up, idle (sometimes)
24K views 17 replies 6 participants last post by  DeBlas66
#1 ·
I have a 2004 WRX w/ 55K miles on it, and recently it has started smoking on start up and when i sit at idle. No power loss or anything, and it doesn't seem like its affecting the power. I just bought the car, and had the oil changed right before I picked it up. It did sit for a few months before I got it. My coolant was low, but it doesn't smell like burning coolant. Oil changed about 300 miles ago. It's cold around here, but even after the car warms up i get intermittent white smoke at idle. No problems whatsoever with oil level or engine overheating. Any ideas?
#4 ·
my is a 04 with 51k and it does the same thing but it goes away as soon as the engine warms up and is faily normal for these cars
#5 ·
Oh good, I'm glad to hear that this is normal. I just bought an 04' also and it does the same thing. I was assuming it was just because of the cold temperature and the car wasn't warmed up either.
So will it do this in the summer also when the weather warms up?
#7 ·
yep it's just the condensation of ur exhaust, seems to happen mostly in cold weather.
I like when it does that :) (i like messing around with the smoke that comes out your mouth in the cold, so i like it with my car too:) ), its cool when you tell your friend or someone to rev it alittle a puff of smoke comes out, IMO looks BEASTLY!!!!!
#8 ·
would be fun to play in but I am catless and that white smoke smells a little to much to go frolicking around in
#9 ·
This doesn't look like the condensation cloud that happens when it's cold. This can happen midday when the car is warm or in the morning when it's cold. It doesn't necessarily go away when the car gets up to temperature (but the car never overheats).
#11 ·
You can usually see everyone's exhaust smoke in the cold weather.
Like someone above said, it's like being able to see your breath in the winter.
If the cloud is very thick and not at all transparent and constant, then I would worry.
But if it's just some smoke (that's not blue or black) and it's cold out, it's nothing.
#12 ·
ok, i will say it again: this is not just happening in cold weather. It is cold around here in the morning, but it happens when its 40-50, and when the car is warmed up. I'm almost positive this is not just condensation, it is too thick (not really thick, but doesn't dissipate like water vapor).
#13 ·
It is nothing to worry about. The vapor that you are seeing depends on many things including: humidity, temperature, etc. There is no need to worry unless the smoke is blue or black. The tip on your exhaust will be black b/c you drive a turbo vehicle, that's just how it is. Excessive black smoke is an indicator of another problem, usually something to do with the intake tract somewhere. Blue smoke means you're burning oil as I have posted before. If you have a stainless exhaust, the condensation is nothing to worry about because it won't hurt your car at all.
Don't worry about it!:thumbup:
#17 ·
Thanks for the replies everyone, but today I checked my coolant and it seems to be low. I started the car when it was ~50 outside and it looked like the picture below (None of the other cars on the road were smoking/steaming at this point). Even after warming up, that was what the exhaust looked like. Also, when I shut the car off, a bit of steam continues to come off the exhaust tip for a bit. Remember, this is happening both before and after the car warms up. I'm starting to think it isn't just condensation. I'm going to fill up the coolant reservoir before a long drive home (80 miles) and see what it looks like when I get there. Any more ideas given the new info and the pic.
