What's needed for a bigger turbo on my wrx
27K views 49 replies 10 participants last post by  Ampliified
#1 ·
Blew the engine on my 05 wrx, getting new engine put in by subaru dealer, what is needed to go to a gt 3076 turbo safely?
#2 ·
wow, a gt30 huh. I hope you have deep pockets. To properly run this turbo you will need alot of internal work as well as everything else. Why not go for a 20g, or one of the common vf series turbo's, like the vf52 or vf39 etc. However at the very least you will need a bigger fuel pump, injectors, proper engine management and a tune. Look around for better options. A gt3076 is a big jump and will require thousands in upgrades to be ran.
#4 ·
Must be a very very conservative tune with low psi in order for it to run safely. If not, your friends wrx may be a ticking time bomb. This turbo is usually used by people that have BUILT their engines to handle that kind of power. You know that this particular turbo is good up to around 500whp right? Unless subaru is installing a built block in your car, stay away.
#9 ·
Blouch makes a very good turbo. So, yes, i would put them right up there with garrett. The TD06 is a popular upgrade for our cars. The only mods you should really need to run it is bigger fuel pump, injectors, a better intercooler, and a tune. And again it is a direct bolt on replacement.
#14 ·
Agreed, And this is the point im trying to get across to him. You cant just buy a big turbo and slap it on our cars. But a 20g will be much easier to handle than what he was originally interested in. If it was my build i would probably do a 16g.
#13 ·
A FMIC would be fine if ran with the 20g. But it is not needed. Look up process west intercoolers. They make a very nice top mount for our cars that would be perfect for your build. Plus it would be cheaper. And since this is your first build of a car like this. Do lots of research. Once you think your brain is full of subaru tuning knowledge, read everything again. These cars can be very tempermental and require a pro-tune for pretty much every upgrade after a stage 2 setup.
#22 · (Edited)
The gears are the main issue really. I mean the upgraded clutch will help. But wrx's are famous for glass-like gearboxs. The newer one's arent as bad as the older, but still arent the best. Anything above 350wtrq can cause issues with your tranny. However, the way you drive also plays a part it in. If you are out there banging gears like you are shooting the next fast and the furious movie and launching your car at every red light like a 16 year old then obviously the tranny will go out much much sooner.
#29 ·
Haha, good catch. I meant to say torque. (fixed) And you are right about the clutch wanting to be the weak point. Clutches are much cheaper than gearsets! And OP, intakes pretty much require a tune. However, and lytlec correct me if im wrong here, but the older wrx's were able to run intakes without a tune. If i am correct on that then the intake should be fine. Although at this time with your car being stock is basically just a noise maker.
