what temp should oil be before driving ?
39K views 19 replies 13 participants last post by  hjames777
#1 ·
i warm my car up to 120 ( oil temp ) before i put it in gear .
is it necessary on these cars to do that ?
when i got an impreza a couple years ago , they told me it didnt need to be warmed up .
#7 ·
Personally, i don't let the car sit more than a few seconds before backing it out of my garage and driving to work, but i always try to keep it under 3500 RPM with no WOT or sudden acceleration until about 10 mins, which is about twice as long as it takes for the dash temp meter to stabilize, which, as I understand, is the general rule of thumb for how long it takes for all components to reach operating temps
or something like that
#11 ·
Don't idle for long periods of time. Get in your car, start it, get your belt on, air con or heat set, radio going and drive away. So a grand total of 30 seconds.
Don't flog the car until oil temp and pressure has stabilized, it usually takes twice as long or longer than the coolant temp.
#14 ·
10mins seems way to long, seems like there would be some carbon build up or other things that would come from that
i do about 1or2 mins at most and thats because im reading the manual (just got on Saturday)
then dont open it up for a few miles, as of course if cold you will have higher oil pressure with load then when warmed up
think more of a focus should be looking it cool down after driving, or staying out of boost the last couple miles before parking
#15 ·
Your turbo is oil and coolant fed, it shouldn't take hardly any time to return to a safe temp to shut off. Sitting around for 5 minutes waiting for it to cool down is not helping. Unless you just got off a hot lap or quarter mile or something.
