Hi! I'm coming for a desperate need of help.
I've been having a weird problem with my car for more than a year now and it's getting quite annoying and even dangerous.
I will explain what I've been doing first:
After trying some basic troubleshooting by myself (MAF cleaning, etc) I took the car to the mechanic. After two weeks of driving it himself with a PC plugged in, he found the MAF and O2 sensor near the midpipe, where randomly giving weird readings, and the drivers side sparks plugs where a bit soaked in oil on the threads.
He replaced the MAF, O2 sensor and put 2 new spark plugs.
The car is stock and there's only a small leak on the driver's side valve cover.
At first I felt the car became very smooth in its acceleration, everything was working fine and after some driving the ECU had all the readings to build all the power again.
But sadly the problem came back from nowhere, and I will describe it next.
Now for the symptoms, which always happen in the same sequence:
Drive normally, encounter a slow car and drive slowly at fixed speed, rpm not low nor too high.
Try to accelerate and suddenly car bogs and can't accelerate, similar to when you forget the choke on a carburator motorcycle and try to accelerate.
When it finally starts to accelerate, there is no turbo power, the car feels atmospheric, lacking in turbo force.
The car will then run smooth but with this lack of power until I find a long straight where to push from 2nd to 3rd gear all the way up the rpm.
At 4500-5000rpm in 3rd gear suddenly the turbo thrust is back and the car runs normally again with all it's power and the turbo pushing.
Also I'm under the impression that it's drinking a lot more fuel than it should. (Difficult to tell with these cars that already have bad mileage).
Has anyone had a similar problem? Do you have an idea for what to try next?
I really don't want to be spending money blindly with parts and not getting results (as what has already happened with MAF+O2 sensor 😥)
Thanks all!
Thanks all!
