Wanting to remove the Rev limiter
1 reading
18K views 14 replies 6 participants last post by  MainFrame
#1 ·
Is there anyway to remove the rev limiter so it can rev all the way to redline? If so, will this void my warranty?
#2 ·
There's a reason why your vehicle has a rev limiter. I wouldn't suggest removing it as it would be easy to damage/destroy engine internals doing this. It is possible to do but messing with the factory ECU in any way could cause Subaru to deny a warranty claim if you were to have any issues in the future.
#4 · (Edited)
... what?
The fuel cutoff (rev limiter) is at a higher rpm than redline....
Sent from my SAMSUNG-SM-G890A using Tapatalk
#5 · (Edited)
Yes.
It already does.
I would certainly hope so.
I'm still unclear what you'd like to do though, because the car can redline as-is, right now. If you cannot reach redline there is something likely wrong with your particular car, and if you post the symptoms maybe someone can help you?
#10 ·
Sorry forget tot mention. I have a 2016 WRX Limited and when I have an aftermarket exhaust and when i am sitting in park I would like to be able to redline to 6700 rpms (which is redline on my engine). I would like to hear the engine rev up and I'm curious if it takes a Cobb tune or anything like that.
#11 ·
Do you have a CVT? Is that what this is about?
