up-pipe worth it or not?
16K views 44 replies 18 participants last post by  brfatal
#1 ·
Hey, I have an 02 Bugeye and was looking at a relatively cheap up-pipe, its 40 bucks, and is gutted soo no cat, and its a Turbo XS model. Would it be worth it to buy if I still have the stock exhaust on it? I just got the car and in the future I WILL be putting an aftermarket CBE on it though....
Thanks....
#2 ·
realistically any upgrade to the stock exhaust system should benefit the car. Just don't get something cheap off ebay that'll burn itself up...if your not going with the Cobb downpipe i've seen some pretty cheap nvidia exhaust dp's which the second or 3rd best brand i'd choose over Cobb...
If I was you I would just save up and buy a new or used turbo back full system. I HAVE seen them go for 500-600 which is not impossible to find.
~Erakem
#3 ·
Hmmm thanks I will probably do that then. Just out of curiosity do you think the Up-Pipe would increase the boxer rumble noise or no? Oh and would and un resonated midpipe by P&L motorsprts be worth it for a 100 bucks? Say I get bot and install for only 140, would that be equivelant to a CBE system, sound wise I mean?
#5 · (Edited)
I never said that.
You probably wont see much noise difference. Just depends on the muffler honestly, I have the stock Dual tip with a Cobb Up pipe and it sounds exactly the same...
What I was saying was regardless of whatever aftermarket piece you add too it, it will make it run that much better.. besides I've heard some pretty nasty stories of not replacing your up pipe on the WRX's....
Say goodbye to pitting and broken turbine fans with a nice Up Pipe....
#7 ·
AshyKnuttz said:
oh no i was just wondering, im still learning about all this stuff and dont really know the difference between turboback and catback
Turboback is the entire exhaust post-turbo, while a catback is the exhaust post-catalytic converters
Explained a little better?
#11 ·
The UP on our model year is basically more of a preventative maintenance item. It won't really net you any power gains but it will delete the CAT that sits RIGHT before the turbo. There has been incidents where the pre-turbo cat has come apart and disintegrated into the turbo destroying it.
If anything, install a catless UP for the piece of mind knowing that you don't have a ticking time-bomb waiting to annihilate your turbo.
EDIT: You can also just take your stock UP, gut the cat out of it, and replace, or find a used STI UP on the cheap.
#12 ·
if you can get a TurboXS model for 40 bucks, do it. It isnt hardly worth the time to gut your stocker, and plus, that is what a gutted stocker will run you if you bought it.
The uppipe will not change the tone of the exhaust, but it will bring out the noise of the turbo spooling a good bit. Throttle response will be better, as well the turbo spooling earlier. But above all that, it gets rid of the catalytic converter before the turbo. So, buy it.:)
#13 ·
if you already have a gutted turbo xs up pipe, it would be pointless to buy another. The main reason people get an aftermarket up pipe is primarily to get rid of the cat-but you already go that part out of the way. Swapping a catless up pipe for another catless would net you like less than 5 hp.
Btw the order of exhaust flow on our cars is:
Header, Uppipe, Turbo, Downpipe(Cat), And Catback(which includes the mid pipe and the rest)
it's the same for just about every turbo car
#17 ·
nowhere did he say he already had a catless UP.
#16 ·
AshyKnuttz said:
but with aftermarket uppipe and downpipes is more than a noise maker(lol) no?
Catalytic converters are very restrictive to airflow. You need to increase airflow in order to make power. If you replace your OEM catted pieces with aftermarket catless ones, you achieve this.
#19 ·
a downpipe also decreases turbo spool time and gives you less backpressure past the turbo. with just a catback, it would be like fatal said-just a noisemaker, since the most restrictive part of the exhaust is still right at the downpipe.
#22 ·
Thanks for the input guys...
Ive decided to just buy a set of OBX Headers that have an attatched caless uppipe. I found a great deal through a friend for only $150 and their brand new. I will be installing them soon and will let you know the results...I will try and get some pics up as well.
#27 ·
Trust me hes right.
Just because they are powder coated in shinny doesn't make them invincible.
Usually the cheaper the product the ****tier the metal...and welds...Besides the heads shouldn't really be touched with unless you honestly plan to be putting out over 350-400 to the wheels in a Subaru.
If you are I would just say wrap the stock headers and go call it good..
#30 ·
on the whole header thing trust them they will crack. also i dont know why people like them they change the deep agressive sound that the wrx brings. And on the whole up pipe thing you will notice a slight increase in spool and a little hp gain. And it is good for your car you dont want your stock up pipe' cat to break apart and ruin ur turbo
#31 ·
AshyKnuttz said:
so you're saying is BEST to leave the headers stock? theres something new i learn :D u guys are great, i woulda bought headers soon after the exhaust system..and probably regret it had u guys not said anything
If anything, do a port & polish job on them
#32 ·
Yes the UP is worth it. It will affect the sound, you will hear the turbo better etc.
To clear up a bunch of stuff -
There are two cats after the turbo (not one). They are both replaced by an aftermarket DP. The DP allows you to run a stage II tune (significant gains for all). The DP is therefore much more important than the catback.
You do not need to go catless, a high flow cat in the DP will be ostensibly just as good and will help with emissions.
They were saying that the stock headers are the best construction - you can get them ported and polished (& coated) though for a significant improvement.
You will need a tune or an upgraded map to safely run a DP, and to see good gains from the other parts.
#36 ·
Your 07 WRX doesnt even have a catted UP why in the world would you add one?
#42 ·
Do not mean to hijack the thread but I just got a 06 sti up pipe for my 05 wrx, it said in the unabombers manifesto that all years are interchangeable.
I guess my question is did Subaru just change up the headers a little for the 2.5l and keep the up pipe the same?
In addition, for any one who did the swap, was there any tweaking to the up needed?
#44 ·
Thank you for the answer. Now on the engine management side of things, I have a cat back on my car already and would like to put on the up pipe as well. I read the EM section that said I should be good with just a cb or just an up, but what about both. I know the Ecu on the 05/04s are not as forgiving as the 02/03s.
Can I run both the cb and up with out doing damage to the engine of my car with no tune?
