Hello, I've been a proud owner of an 06 WRX for the last 15 years. My car is running a stage 3 from Cobb and only has 12K on the odometer. I have been worrying about my timing belt snapping due to old age. I went online and found that it should be replaced after 7 to 10 yrs regardless of mileage. My car has spent most of its life in a garage. The garage doesn't get very hot or cold and the car is only driven about 150 miles yearly. I do plan on getting my car in the 500 hp range eventually. I do drive the car pretty hard when I take it out, so I don't know if the extra output has prematurely stretch the belt. The car is running fine at the moment.
My questions are:
1. Should I really worry about the belt being deteriorated due to age?
2. If I change the belt at 12K miles, do I also need to change everything else recommended (water pump, tensioner, bearings,)?
3. Are the high performance belts made by Greddy and HKS worth the extra money over OEM?
My questions are:
