tgv deletes
1 reading
18K views 19 replies 8 participants last post by  Wrinklechops
#1 ·
hey guys
is anyone running tgv deletes?i was looking at them and cant tell if there for the sti 2.5,dont see anything on them foe the 2.0.are they worth it or should i stay stock on them?
#4 ·
TGV's are an emission control device...plain and simple.
The only con is you shouldnt remove them without a tune...and if you dont delete the CEL you'll get a CEl if you gut them.
#6 ·
I believe the TGV's like the UP are for start up emissions only...I could be wrong.
#7 ·
Nope 100% right.There are two ways the TGV delete can be done.Total removal- where everything is removed, including the sensors and rods, or where just the divider plate and throttle plates are removed leaving the rod and sensors intact.Total removal requires a tune to overcome the CEL's/DTC's and if the rod and sensors are kept then no tune is really needed unless you are having major problems with cold starts.This can be tuned out by changing the cold start enrichment parameters in the ECU.
#10 ·
so for you veterans of the WRX, i have AccessTUNER (bascially streettuner) and can turn off CELs.
Do you think it would be worth my time to go in there and bascially tear all the TGV equipment out, and port it at the same time?
I have the tools to do it, so no problems there, i just dont want to screw something fragile up.
#11 ·
Yes
#14 ·
i found one: DIY TGV/Sensor Deletes. step by step(pics) - NASIOC
now if i just take out rod and plates leaving the sensor(so i dnot need a tune just yet) and not grind out the piece that divide the main holes will i see the same gains or any gain at all?
