I was just wondering what stage 2 sti's make on the dyno and what would take a wrx{02-05} to beat it.
+1 plus each car will have slightly different results.the question cant really be answered 100%. dyno numbers will vary because every dyno will read differently & every stage 2 tune will be a little bit different (opensource, OTS maps, etc).
beat it at what? Peak numbers on a dyno? There is a lot more to performance then simply peak numbers.and what would take a wrx{02-05} to beat it.
Stage 2 STI should produce around the 290-310 whp, depending on quality of tune, elevation, mods, etc..... and run somewhere in the neighborhood of 12.8 - 13.2... again, depending on mods.
An 02-05 WRX, with a Walbro 255, a set of 850cc injectors, a full TBE, a 20G turbo (minimum)... and a PROPER tune should do the trick. Of course, much depends on the driver....
..... and how long you're transmission lasts.
That was the point....With a 20g and all supporting mods youll mop the floor with a stage 2 STi in the 1/4,
