On several TSBs, Subaru has alluded to 1/3 of a quarter per 1200 miles as the acceptable limit for oil consumption. If the car really consumed 3.5 quarts, you are more than 300% of the acceptable limit.
Perform a compression and leak down test and inspect/replace the PCV valve. However, it’s very possible that your bearings are already toast from low oil pressure.
