Low vacuum, but no leak? help
21K views 27 replies 6 participants last post by  219673
#1 ·
Alright folks so i have been chasing what i assumed was a vacuum leak forever now. i believed i had a leak because my vacuum was at about -8 psi during idle. I have performed multiple boost leak tests even using fog and smoke. i did find a couple small leaks on a hose and my fmic but those are fixed and the whole system holds pressure very well now. still no change in vacuum at idle. I ordered a gasket and cleaned my iacv to see if this would help. no luck.. What would cause this besides a leak? Car is still running strong. hitting target boost of 18psi and idle does not wander. However today it is now even lowering staying around -7psi at idle.. Is my engine slowly going kaput? I have not performed a compression test yet but would this by my next step.? any help would be appreciated.
mods include-
fmic
short ram intake
up pipe
tbe
V2 AP
565cc injectors
5k miles on iridium ngks
#2 ·
My car regularly pulls -7 to -8 psi at idle. When I am coasting at speed, It'll go to -10 to -11 psi (max neg. value on the gauge) when the throttle is closed and the injectors are off too. I don't think that you have a problem. Just to be sure, what do your fuel trims look like?
#3 ·
-8 PSI is normal. Vacuum pressure will vary depending on ambient conditions. It is tied to the volumetric efficiency of the engine and the ambient pressure/temperature.
#5 ·
My lamco gauge pod shows about -.05 mpa at idle which relates to around -7 psi. My accessport also displays psi when monitoring boost(vacuum a idle) and i get the same readout. My tuner and i haven't run into any real issues about this low vacuum, but i'm curious as to why mine is just so low without a leak. When coasting with a closed throttle i see about -10 to -11 as well but i don't know if this confirms or means anything? Maybe im just worried? I do live in the hills at about 5200 feet above sea level.. I will take a closer look at my fuel trims today. Thanks for the replies fellas. Much appreciated
#7 ·
I think you are a bit over your head here.
When coasting/throttle plate closed, the motor is still pumping air through the engine. Since you are pulling air through the same small opening as idle, the effective vacuum is much higher. This is normal. You DON'T have low vacuum.
#6 ·
I guess i should thought i'm not too familiar with volumetric efficency but if the incerdibly thin air and high elevation here can't effect it that much, does that mean that my engine is becoming less efficient thus creating less vacuum? I feel as if i should go through with the compression test..
#12 ·
Any solution ?? ... I have the same problem low vaccum to -8 and when I drive it goes up to -10...
but my problem does not end here... because of the low vaccum my BOV is opening late and that is mistreating my turbo: / please i need help!
#13 ·
Remove the blow off valve and install the actual part the car needs to start. If that doesn't solve it a BOV wont open because of high vacuum and your vacuum is normal.
In my area i vary between 600-900ft above sea level and -11 on cobbs ap was normal as was -9 depending on the day.
