Hello guys.. im having this issue for almost 5 years no prevail. Ive been here and there unfortunately no solution..i hope you guys can help this issue n very much appreciated.
I owned a wrx 2006 ej25. As mention above, my car is having issue with the timing degree..
With the WOT at 3rd gear the ignition timing degree start at 17 degree from 3000 rpm and went down to 15 13 and sometime 12 the minimum.. i can feel that im losing power at high rpm.
I really dont know what causing the pulling of timing.. when the tunner try to do some tweaking on the ignition timing degree he said that " the ignition timing degree is not listening to me" what he meant is that when he try to change the degree nothing happen. He also mention that i have a fake knock.. the figures of the knock is unbelievable. If its a real knock my engine would have already been blown as per my tuner.. i have check the surrounding of the engine theres no loosing nut or anything on top of the block..
I have not tried changing the ecu as it is very limited here in my country..
So im stuck with this problem.. bare in mind that driving normally i have no issue.. only when WOT is the problem.. the higher the gear the lower the ignition degree.
I m sorry for the poor english..
Any idea is welcome
Any idea is welcome
