How high does oil pressure get with ej equipped cars
7.1K views 14 replies 3 participants last post by  219673
#1 ·
I am trying to determine what psi oil pressure gauge is best for my application. I see some that have a max of 100 and some of 150. Would oil pressures pass 100 with ej engines?
#8 ·
So here's the deal -- it doesn't matter what other cars show. The EJ is designed to operate (at idle) in the 10s of PSI and between 40 and 80 PSI at maximum demand.
Cold pressure will obviously be higher.
#12 ·
If you are going full throttle on a cold engine, the oil pressure gauge is that last thing you need to be worrying about.
Sounds like you've already made your decision. No skin off my back. It's your money. Just don't blow it on garbage gauges.
