FA20DIT Head Gasket Replacement
2K views 9 replies 4 participants last post by  silver_scooby
#1 ·
My son has a 2015 WRX with 180k miles on it and its starting to look like it has a blown head gasket. It's using coolant (haven't overheated it yet), and there's an oily deposit on the radiator cap when I checked the coolant the last couple of times. My son doesn't have a bunch of money to throw at this car and I'd consider myself fairly experienced with engine removal, rebuild, etc, so at this point we're planning to replace the head gasket(s) ourselves.
I spent a few years with an EJ205 and am familiar with the head gasket difficulties with those engines; particularly with the limited success of replacing head gaskets without doing machine work. I've done some searching on the interwebs for information on head gasket replacement on the FA20DIT, but have found surprisingly little. So I have a few questions for those here familiar with these engines.
1. Is there any reason I should be looking at another failure point on this engine, given loss of coolant and oil in the radiator? We just discovered this issue and I haven't done much investigation beyond checking the radiator.
2. Is it reasonable to think that I can replace the head gaskets on this engine and have it last a while? Seems few had long term success replacing head gaskets on the EJ without machine work. Is the FA20DIT similar?
3. What else would you suggest replacing while we have the engine out? At this point, I'm planning to do valve seals, front/rear main, timing chain and anything else I find that needs attention.
4. Any advice on good sources for good quality gaskets and other parts? Is OEM the only way to go, or is something like Mahle a good option?
Thanks in advance,
#7 ·
It's more common to see additional signs like oil burning and consumption, but it can happen. I would rule it out first. Seal failures were common on K04 turbochargers and this is exactly the failure that occurred on my wife's old MS3.
If I were in your shoes, I would perform a coolant system pressure test first, then inspect the turbocharger for signs of failure (you'll typically see oil residue and corrosion on the turbine and sometimes the compressor). If the system pressure test fails AND the turbocharger looks to be in good condition, suspect head gasket.
This part is important: the internet loves to poke at Subarus for head gasket failures, but this wasn't actually a common failure in any WRX or STI. It was a problem with the single-layer gaskets on the SOHC 2.5L NA motor. The later-model Impreza and all WRX/STI are just as susceptible to HG failure as any other brand at stock output.
#6 ·
I'd only select OEM on the critical gaskets/parts not easily accessible later on (e.g., rear main, head gasket, etc.). Aisin is good for your timing belt, water pump, etc. items there if you skip OEM.
Mahle is fine in my experience. I use to like Fel-Pro but have not had great luck with their stuff post-COVID. Dorman seems to always be a 50:50 shot on whether it lasts, with the exception of their "OEM improved" parts I really like (such as their metal-instead-of-plastic connection GM heater hoses).
As for "sources", I buy all my OEM parts at the below site. *BUT change the dealer you're buying from when doing local pick-up to compare prices - they are all different by dealer. Also, they do not honor the quoted online price in-store if you just walk-in; upon learning this recently, I literally stood in front of the guy at the counter and ordered on my phone, saving $30 on a pair of fucking half moons LOL.
#8 ·
I'll go ahead with the system pressure test. Seems that would be a good first step.
However, I'm having a hard time getting on board with the turbo leak theory. In all the turbos I've dealt with, the coolant and oil passages are separated by the CHRA casting; the seal condition wouldn't have any bearing on whether or not the two fluids mix. In that situation, the only way to get oil in your coolant via the turbo is if the housing was cracked. Am I correct, or is there something unique about the turbo on the 15+ WRX that would allow this to happen?
Don't get me wrong, I think I'd prefer the issue to be the turbo instead of a head gasket, but I'm having a hard time working through exactly how that would happen.
Thanks,
Marshal
#9 ·
You are correct to question.
This depends on the bearing and cartridge design. I'm not sure about the design of the Garret turbo on the FA20F, but best to rule it out before tearing the motor open.
