Does AWD help in the rain?
62K views 69 replies 19 participants last post by  zax
#1 ·
So it's been a while since I've been on here. First off I wanna say hi and how is everyone doing?:wave:
I've owned my WRX for about 3-4 months and I remember my brother asking me if AWD helps in the rain when I first got my car, which is crazy because the very first day I brought the car home and had to drive to work, it started raining out of nowhere(typical in South Florida). At first I didn't know how to answer because I was inexperienced in how an AWD vehicle would behave in inclement weather. Up to that point, I had only driven a truck and a minivan in the rain and both reacted differently.
For those of you who live in South Florida, you know that it's been raining quite a lot these past few days (funny because it's pouring outside as I type this). And every time I drive to work/school in the rain, that question keeps coming back to my mind. And I still don't have an answer, besides I don't wanna be "that guy" who pushes the car's limits in bad weather since I'm afraid of losing control.
So I gotta ask you guys here, does AWD actually help in the rain? Or any inclement weather for that matter, since some of you guys live up north where there's snow.
Thanks in advance.
#2 ·
It helps but that does not mean you should drive recklessly also it doesn't prevent your car from hydroplaning. Also the quality of you tires is another factor.
#37 ·
Tires help more. As does sensible driving.
^^this.
Of course AWD helps in inclement conditions.. but obviously it doesn't change the laws of physics. Tires are typically far more impactful as that is what actually contacts the driving surface. Additionally, not all AWD systems are created equal. Depending on what you are trying to achieve some systems will help a little more than others.
Gaining a firmer understanding of what is actually happening on the car and how it interacts with the driving surface in different conditions is probably the single best thing that helps people driving especially in conditions other than dry clean pavement. That all will bring you to better understand how big the role that different tires will play in the whole equation and how relatively minor the role AWD often plays.
One thing I believe really helps illustrate things is thinking about the fact that people used to get around pretty darn well in harsh cold winter areas for many many years with RWD cars.
#6 ·
All wheel drive puts power to 4 corners all the time, much like a 4wd truck or jeep. That helps you roll forward, however power at 4 corners has downsides. Much like a rwd car will loose the rear because the rear tires lose traction, and you totally lose steering on fwd cars because the front breaks traction, on 4wd/awd the cars tend to just slide sideways.
I see it every year, awd SUVs, cars, jeeps, etc sitting in a ditch where they just slid out.
The most important factors are your tires. No matter how many wheels you have driving or what they are it provides no benefit in braking and very little in cornering.
Sent from my Nexus 6 using Tapatalk
#7 ·
OP, Look at it this way.
AWD/4WD vehicles have a traction advantage on wet/loose/frozen surfaces. That is 'traction' under power.
Any instance where you are not under power negates any advantage you may have had. Power-off traction is more a function of balance and tread. Take a completely identical WRX to yours and disconnect the rear wheels from the drive-train and your car will still behave identically rolling through a wet corner.
#8 ·
There are a lot of blind curves and steep hills where I live, and the traction under acceleration is always a concern for me. I'm so tired of trying to pull out into a gap in traffic just to spin the wheels in water or gravel run-off, setting off traction control which cuts power, causing me to nearly get hit. That's why I decided to give AWD a shot, but in all other aspects, such as lateral grip, handling, and cornering, AWD isn't better, it's just different.
#10 ·
AWD is excellent at preventing the tail from stepping out under power. But this is not improving handling. It's really aiding acceleration.Once the tires' grip limit is reached, no more can be created.This applies to wet or snowy roads equally.
#16 ·
How putting power to the tires responsible for turning limiting traction now in 2 directions helps is beyond my understanding.
A tire has only a certain about of friction it can provide, when the friction is used for braking, accelerating, turning etc then you have less grip for a subsequent direction. For example braking limits steering, acceleration kills your lateral grip.
Four tires free rolling through a corner is going to provide the maximum amount of traction to turn as possible. Any power put down will cut the lateral friction, more tires pushing forward, less friction to turn. It's exactly what causes awd and fwd cars to understeer so badly and why so many companies are pushing to yaw control on their awd systems to overcome that.
People view rwd as the worst because there is usually the least amount of weight over the rear, in cornering under power the back end comes out making it hard to recover from.
Front wheel drive has no steering, your front tires are sliding what desides what direction you go? You've lost all of your steering.
Awd pushes the car sideways, killing much if not all of your steering and the back end slides out. You see it every year in the winter. Awd vehicles allover the ditches because people have less fear because 4wd.
There is a diagram that floats around from time to time with an infographic that makes it simple to see and understand I will see if I can hunt it down.
#33 ·
I agree with a lot of what you said, except for the RWD oversteer being hard to recover from. IMO, severe understeer is far more difficult to recover from because, as you said, you end up in the ditch. With RWD, it's pretty easy to get out of the power and snap the rear back into place...I pulled of a pretty spectacular save with my '03 S10 Xtreme which was lowered at the time. The road in question has a speed limit of 25mph, and it was raining. I had a Ford tailgating me and I was pushed to 45mph. Topped a hill, unloaded the rear end, just in time for an S-curve. As I turned right, the rear snapped around. I was going sideways toward a guardrail. I let off the throttle, quickly jerked the wheel to the left, and the rear end snapped around perfectly for the left hand turn.
The kind of unrecoverable oversteer you speak of would be more in line with rear or mid-engine cars like the 911 or MR2. But there are other cars that are poorly balanced, or that are too stiff in the rear, or too soft in the front, and will oversteer badly regardless of drivetrain layout. I learned a hard lesson on FWD oversteer...entered a corner too hot, and let off the throttle halfway through (I may have even tapped the brakes, but I really don't remember exactly). Big mistake. It was my wife's '03 Civic, and I was used to my S10, and my previous Firebirds, so my RWD instincts kicked in and I ended up fishtailing a few times before doing a 180, ending up in the oncoming lane (it was dry, btw). The only way to recover from that was to push through, but I had been conditioned to lift the throttle in that situation. That experience haunted me for years.
Not arguing with 7 paragraphs. ^
But, Jaguar dude, you're saying that AWD provides no benefits in the rain?
All I can do is relay my experience. There is an uphill switchback, near my home. It rains, here, all the time. Even on wet asphalt, I can bust up that hill, in my Legacy. Something I cannot do in my RWD Chevy pickup or my previous FWD Carolla.
You can't really compare a Legacy to a Corolla or Chevy pickup and make generalizations about AWD, RWD, and FWD. Those vehicles couldn't be more varied. Tire size and tread type, suspension type. There's not really a perfect comparison, since there are no FWD or RWD Legacies, but you could at least compare cars in the same midsize segment. Accord, Acura TL, Maxima, BMW 3-series, Infinity G35/37, Lexus IS, etc.
#17 · (Edited)
#20 ·
Not a jaguar cheif. And yes I'm saying it flat out clear as crystal. No, it is not better in the rain.
Your tires are the thing at hand. More wheels pushing less tires have full grip for lateral traction. It's a very simple concept and people get it wrong every day. I've made a lot of money pulling "my awd is superior" people out of a snow bank or drainage ditch in a jeep, in 2wd because I understand how the traction limits of my tires works.
#22 ·
Actually AWD may be better in the rain -- but not for the reasons we'd typically think of. In an AWD car going the same speed as a RWD or FWD, the torque is split between 4 tires instead of 2. So at the limits of breaking loose because because of low traction and acceleration in a 2WD, the AWD is roughly only halfway there so would not be as close to breaking loose. This is all assuming the limits are reached because of low traction (wet road) and accelerating through turns. BUUUT, if the adhesion limits are reached simply be the combination of low traction conditions and speed through the turn, then there is no difference in AWD vs 2WD. So there it is again -- "it depends."
In simpler words: If you are on-the-gas through turns in the rain the AWD is likely better if not going too fast. If going so fast that you are near sliding without even being on-the-gas, then all drive types will be equally as near sliding.
#25 ·
Take your car to the limit of traction. The car slides directly off the side of the road like someone pushed the car sideways.
It doesn't matter how many wheels have power, you can't increase the grip of your tires, period. Any argument you make against that is wrong.
The awd 50% power to all wheels making tires less likely to reach their grip limit is not exactly how that works. You now limit traction on all tires instead of just two. Thus the sideways slide.
#26 ·
This comment has nothing to do with the OP's question. I believe the key word is "help".
No where did the OP ask about invincibility.
#29 ·
Awd doesn't add traction. What is so hard to understand about that? Awd has no effect your traction on braking and turning, the two critical factors. Absolutely zero. Acceleration from a dead stop may see an advantage, that is the only situation it may help. However not much life or death situations come from rolling out from a stop.
Tires affect traction. Awd does absolutely nothing to help you besides make you think you have increased traction because you have no idea what it really does. There is no contradiction there is you trying to prove something that is false.
#30 · (Edited)
Nope. I said that you contradicted yourself, because you stated that helping is the same as completing the task, entirely and as successfully as possible.
I contend that "help" is assisting, aiding or making easier.
If AWD does not aid traction, what are the advantages, if any, of AWD?
#35 ·
The correct vehicle layout is mid-engined with all wheels driven constantly. The rest is a compromise of some sort or other.
Number and location of driven wheels affect behaviour beyond the limit of adhesion, and attitude of the vehicle as that grip limit is approached and exceeded.
