Windshield chips (very tiny)
1 reading
3.5K views 12 replies 10 participants last post by  sexyrex
#1 ·
Had my WRX for 6 months and already I can see hundreds of very tiny dots where road crap from trucks or sand from the roads has made there mark on my windshield. No I don't tailgate. Here in Washington state we have sand on the roads in the winter. Also the ratio of semi trucks to cars is like 1 out of 20 sometimes.
Is there any inexpensive way to buff these out or product to apply to the windshield to make them less noticeable?
I see kits for $500, but I don't want to spend that kind of cash.
Again these are so tiny, but on a sunny day they look very obvious.
Any ideas?
#2 ·
Bah, I have no idea for fixes but Im in the same boat. Rex windshields are known to suck teh wang :baaa: Many people get cracks n' stuff...just something we have to deal with I suppose
#3 ·
I guess if you drive fast enough they aren't as noticeable!
I wonder if there is a "super windshield" out there that would be worth investing in. Not exactly the coolest mod you'll ever do, but it would satisfy picky people like me.
#6 ·
Unfortunatly, there is no such thing as a super windshield. Perfection is hard to come by. There ARE however, different windshields for different applications/needs:
Lexan windshields. Primarily used for race cars, this almost unbreakable polycarbonate (not acrylic like lucite or plexiglass, which we tend to think first) is the same stuff that (after an extensive process ) is used as bullet proof glass. It's great stuff- in my mechanical engineer capacity, I swear by it. I have also been in a race car where the stuff stopped a wheel off another car moving QUITE quickly from kissing me right on the lips. Sounds like what you were thinking of? Well, if it sounds too good to be true- then it is. The stuff performs exactly as I have said-BUT the downside is that the stuff scratches if you sneeze on it. ITs incrediably strong, but very soft (which usually go together- it bends to absorb energy rather than a completly inelastic collision. Glass, on the other hand is extreemly hard, but very brittle) Race cars get around this problem by layering it with a seran-wrap type stuff that absorbs all of the nicks, pits and scratches, and can then be peeled off- perhaps something similar could work for our windshields? Lexan is also not DOT approved, if you're worring about that stuff.
Laminated Glass windshields. These are what you will find about two feet in front of your face on most new cars. There are two thin sheets of glass that sandwich a thin layer of plastic (its called polyvinyl butyrate or PVB for short) The advantages of this method is that it's fairly scratch resistant (hard), light, thin, yet still strong enough to stop anything from entering (or leaving) the car through the windshield ( think of the PVB layer as rebar for cement-it holds up and give support for what would otherwise be a very brittle substance) The downside for this one is that it still is fairly brittle, and due to the thin, untempered glass sheet on the outside, it pitts easily with ANYTHING. I currently have what looks like a bullet hole in my passenger side of the windshield from a rock - its just shattered the outer glass layer, and was stopped by the PVB layer. We'll see how long THAT lasts.......
Tempered Glass windshields. This is the "old" type, but a good one. Litterally, its a sheet of glass that has been heat tempered by rapid heating and cooling. This makes it even harder than regular glass- and less brittle, due to the break up of the rigid crystaline structure found in regular glass. They still use this stuff in rear windows- and if you're lucky, in the side windows as well. (We dont have it in our side windows I don't think- I could be wrong on that one though; its too late and cold for me to go outside to check) This is what we classically think of as "safety glass," inasmuch as it shatters into thousands of tiny, blunt, glass "pebbles" when it breaks. If you have any experiance with older cars, you know that they rarely got the sort of "sand blasted" look in the windshields- its because they used this glass. Its EXTREEMLY stratch and pit resistant. The downside is: its heavy, its expensive, its thick, and you're trading some safety for the pits. Which is the pits.
So, there is no one perfect windshield, and, dispite how many of these damned things I've been through with my WRX already, I still think the laminated ones are the safest and best bet. I am forced to get mine replaced with the OE one because I have the windshield defroster, and on the 04's +, the radio antenna is embedded in the glass. Are there thicker, more robust versions of this laminated glass windsheeld available? Of course. If you can, by all means try it. Otherwise, keep some rainx on it, some glass polish, and don't drive into the sun!
Good Luck.
#7 ·
I think I vaguely remember someone posting something about his insurance company actually allowing him to replace his front windshield once per year without any penalty or increase in his rate...
#8 ·
I'm pretty sure our side windows are tempered... I have first-hand experience as my driver side window shattered in to little pebble like bits all over me during the collision. And none of it was stuck to it ala laminated glass, which I think the front is.
#9 ·
Checked on that one- Yes, you're right. They're tempered- cheap tempered glass, but tempered, which is why they shatter into thousands of glass pebbles (normal glass shatters into thousands of razor sharp fragments, as I'm sure you know.) Windshield is definatly laminated. Thank you for the correction.
#10 ·
I know in Florida it is law that if a windshelid cracks due to a rock or debris or whatever, the insurance company must replace the windsheild free of charge. This is because of course it is a road hazard to be driving around with a cracked windsheild. Check your state law and throw a rock at it :D
#11 ·
i should call and ask my insurance if they cover that. hehe. i was driving on the freeway going back to work from lunch. on the lane next to me was a garbage truck. i saw this rock coming at my car slow motion. it seemed like forever, when all of a sudden BAM hits the windshield and theres like a an inch spider web crack. now aint that a bi0tch.
#12 ·
Man I can relate. I've had my STI for 3 months or so and there are a lot of chips in the windshield already. Just yesterday I was only going about 60 when a truck passed me and "Chip"-a rock flew and barely hit my windshield. I was surpised that it left an indention on the windshield as the pebble seemed to be very small and didn't hit that hard. The windshields are fairly crappy. In my other cars this rarely happened.
#13 ·
i got this tiny spec on my truck coming home from vegas. it bugs me. been ahving bad luck with rocks. to make it worst its right in front of my face. so when i drive i always notice it and it bugs me. it looks as if you can wipe it off but its a chip. booooo
