Trans whine/ gear oil
1 reading
9.2K views 6 replies 6 participants last post by  RomansTenNine
#1 ·
Hello all,
Recently my transmission started to make the 2nd gear whine which subaru, and apparently the internet seems to agree is completely normal. Now I asked the guys at subaru what exactly the problem that causes this, and they said they believe it has to do with a diff bearing. Now I asked if there is anything special that I could do to make the whine not as noisy, and they recommended putting in 90w REDLINE synthetic gear oil. My questions to the forum are what is recommended, what type of oil, is it a diff bearing... Ect.
I am canadian, so lets keep in mind that I might not have your brand..
2011 STi, 84xxx km
#2 ·
You're at 84K and haven't changed your gear oil? That's probably part of your problem. I've heard good things about redline, but I personally prefer Motul 300. The gears whine because they're straight cut, if I'm not mistaken.
#6 ·
Does it only happen in 2nd gear?
Can you shift early or late and see if it is speed related instead of a specific gear.
If the whine is in the differential it should not matter what gear you are in.
I have a GMC van where the rear differential whines loud 45-50 mph, but only there.
It is caused by gear teeth having too much wear and not lining up properly with the mating teeth.
The guy I bought the van from told me he pulled large boats with it and got a new one because
this 1/4 ton was not big enough.
Gear whine is telltale sign of harder use than designed for.
As for a fix, I replaced the oil in my van pumpkin and it did not make a difference.
Some day I will replace the gears.
#7 ·
The Subaru manual for the 2015 WRX recommends different fluid for the manual transmission than it does for the differential. It says you may use 75W90 but that it may cause problems. Redline makes a 75W90 "NS" non-slip that can be used for the MT, while the regular 75W90 without the "NS" designation can be used for the differentials. Since their are some Motul users commenting, has anyone put the Motul 75W90 into their manual transmission on a 2015-2017 WRX and, if so, what have been the results? I am just trying to figure out what options I have for the MT oil. Thank you.
