So I tried to install a Kartboy short shifter today. Tried being the operative word!
Things started off well. I got the stock shifter off without drama, and stopped for a few pictures.
Then I cleaned out the white, plastic "cup", regreased it and the Kartboy shifter. I don't have any snap-ring pliers, but do have a rubber mallet, so that was called into action. One hour and plenty of cussing later, I was no nearer to getting the shifter in. No amount of pounding worked. I tried twisting/hitting the shifter in different positions but to no avail. In frustration, I even resorted the ol' block of wood and hammer combination but also without success. In fact the wood split into two!
Starting to feel like a failure, I tried to put the stock shifter back in and low and behold, that popped in on the third strike of the mallet. Confidence buoyed, I removed it again and had another crack at the KB shifter. The result? The same as before! Running out of time, I therefore reinstalled the stock shifter (which again went in on the third strike) and left it there.
I have watched countless YouTube videos and read lots online and the consensus seems to be that this IS a pita to do. That said, everyone seems to eventually get the shifter in, so that's what I'm going to try to do (again) tomorrow. I also read a thread on here about attaching the shifter to the linkage then pulling back on that, so will have a go at that as well. If that fails then I may have to bite the bullet and buy some of those pliers. Or a bigger mallet!!
