How to use Tactrix
25K views 7 replies 5 participants last post by  lucky
#1 ·
On the COBB AP - I can see how it would be easy to use and easy to flash back to stock.
If I purchase the Tactrix cable - is getting back to stock as easy? Since I have a laptop, is there any reason I wouldn't buy the tactrix cable? (ie, is the COBB AP worth it?)
#2 ·
Tactrix user here. It is very easy. It is the first thing you will ever use the T cable for. You read the ECU and then save it to your computer. Most base maps are even out there online so even if you lose it chances are somebady else has it. I think the debate now is weither or not you have enough time to use tactrix.
#5 ·
I just don't get it... I am really appreciating this forum as it is very useable - I can't find the info I want on other forums.
I want stage I - so I...
1.) Buy the appropriate Tactrix cables
1a.) I presume this purchase comes with software and instructions?
2.) Get a map - how do I do that?
2a.) I presume the above mentioned instructions will tell me where to get a map, and how to download?
I am so stupid.. I know.
#6 ·
Buy tactrix cable, no software, instead download ECUflash and enginuity, you can get both of these here:
http://www.osecuroms.org/
then at the same site find a map, I presume you have a 06 or 07 by the looks of your avatar, if so, and your looking for stage one I suggest gabedudes stage one map, I ran it for a little while and it's a good map spools faster then stock and makes a little more boost. If your looking for stage 2 i would look into 3gsucks map it's pretty good, thats what I'm running on my 07, I have also used the XPT stage 2 map that you can find at XPTtuning.com, I think it's 55 bucks or something like that, but alot of people have had to have that map prof. tuned.
After you get that take your tactrix cable and plug into oBD II port under the steering column.
then look under the dashboard and you will see 2 green connectors that are disconnected, connect them. (Only use when reflashing and pulling maps not when logging).
turn the key all the way on but don't turn the car on, and in ECUflash select read ECU then save the map to a USB drive or something so you don't lose it.
Next Open the map that you want to reflash to your ecu, and select copy to ECU.
Once copied to the ecu turn the ignition off, and pull out the tactrix cable, disconnect the green connectors, and turn the car on.
Let the car warm up, turn it back off, then give it a few hundred miles to get the timing, fuel and boost maps set.
Make sure you log
P.S. scoobypedia is your friend here's the link, http://www.scoobypedia.co.uk/index.php/Knowledge/ECU read through the ECU portion it will answer all your questions.
#8 ·
ecu tuning
kinda new to seen so baer with me i quess they have maps for paticular mods that you have thanx for any reply just trying to decide whether to do ap or just get the cable and like you said do it my self and just be happy well thanx :)
