High beams always on
88 views 5 replies 2 participants last post by  SD_GR
#1 ·
I have a 2011 wrx. When I turn my car on the high beams are always on. When I turn my switch to high beams my low beams turn on. Is this a wiring issue? Or is this how all wrx are?
#6 · (Edited)
You are either misspinned or misswired, assuming your actual switch is OK (it likely is; this is a relatively new car after all).
Check that you have a black earth connection, a red black high and a red/yellow low. Use a VM meter and sort out which wire goes where vs. which wire ought to go where. It's a (-) switching system.
