Cool. BTW, subaru has the shop repair manuals and Technical Service Bulletins available on their website. I recommend you purchase a 3-day subscription and download as much as you can for future reference.
[URL=https://techinfo.subaru.com/stis/]
https://techinfo.subaru.com/stis/[/URL][/URL] I too, have started doing a lot of my own maintenance. I'm a perfectionist...and a few things have aggravated me. I'm sharing them with you so you don't get aggravated when you read the OEM manual and run into hurdles. Here's a few: When replacing the coolant, Subaru says you must add a "conditioner" ... it turns out that the local dealerships don't stock it (so how the heck do they add it when they do a coolant "flush"?); turns out it is basically a stop-leak because of problems they had decades ago with gaskets...but the problem is solved and therefore the dealers don't stock this product. Also, when changing certain parts or fluids, Subaru Shop Manual states to use a new locknut or a new washer...yet the local dealerships don't stock those locknuts or washers (I can't rememeber exatly...Transmission fluid drain/fill washer or differential washers)....so I infer that they don't follow the OEM service manual and just re-use the hardware. Also, you won't find the right subaru branded manual transmission fluid in quart nor gallon containers, well, not even 5-gallon containers at the local dealership...so that tells me they use another brand and they've been having good success (By the way, I was able to order a 5-gallon can of the transmission fluid (Subaru Gear Oil Extra MT)....it wasn't in stock, I did a web order ... shipped to local dealership ... it was expensive; but my son has a Subaru too, and I figure this'll get us both through a couple of fluid changes over the next 3 years).
I'm happy to hear that you've decided to do more of your own maintenance. I applaud you. Cheers.
