In December 2022 I paid to have the whole secondary air system replaced - valves, air pump, and relays. Valves were rusted shut, pump was full of water.
Last month (February) I was working on the seat heater switches. I took the middle console / shifter area apart, disconnected the cigarette lighter underneath the radio, and disconnected the switches. Switches were bad, I've since replaced them and they work (on low power only, but that's a different post).
But back to the disassembly of the shifter area. I left everything unplugged while I waited for the switches in the mail. When I turned the car on next time, I smelled a burning-type smell. Come to find out the secondary air pump fuse (the 60A one) blew.
I am a backyard mechanic and don't know much. I thought maybe leaving the cigarette lighter unplugged caused some kind of electrical hiccup? I put the shifter area back together enough to plug the cigarette lighter back in. I replaced the 60A fuse. And...
It blew again. Crap.
Since then, as mentioned I fixed the seat heater switches. I plugged everything back in. I checked for any shorts I could see in the shifter area - nothing. Last weekend, I removed the cover from the air pump and spun the fan manually - it is free and seems to be working. I tried to test the power coming through the wiring to the pump, but blew up my multimeter (again, remember, I really don't know what I'm doing). I'm going to fix that, find some instructions, and try again. I replaced the 60A fuse, and this time it did not blow.
The secondary air system is definitely not working. The CEL is on and cruise control is flashing. Code P0410. I read somewhere online that the car can go into a limp home mode due to this (limit revs, reduce boost). I don't know about the limited revs (I daily drive pretty casually), but I definitely feel less boost. Is there any truth to limp home mode in this scenario?
I'll update when the multimeter is fixed and I check power to the pump.
Otherwise, any ideas on next steps would be appreciated! Thanks.
-BR
-BR
