crank no start / Ignition grounding issue?
25 views 0 replies 1 participant last post by  samuelmcafee236
#1 ·
So, trying to get my 2007 WRX swap working in my '99 Legacy wagon, got a harness merge from I-Wire a while ago, and I'm working on finishing the swap.
I went to check for spark with a screw driver and ignition coil, and the thing shocked TF outa of me and started?? Then never started again??
I'm suspecting a bad ground somewhere for the Ignition sytem. I got the one that sits on the fuel injector shroud, and put a grounding strap from the block to the chassis. I also sanded and checked the main harness grounds that sit on top of the strut tower.
What am I missing?
