501 - 520 of 583 Posts
Guess I can get back into this thread with the new(ish) car.
2003 WRX wagon, Platinum Silver Metallic.
ENGINE
grimmspeed up pipe
tial 38 ewg
Custom dumptube
grimmspeed iwg bracket
css big top mount
stage 2 clutch
autometer boost gauge(tuned to 18psi)
grimmspeed downpipe
perrin catback exhuast (swapped to STi axleback for noise reduction)
perrin turbo inlet
k&n drop in filter
INTERIOR
07 STI headunit
Autometer boost gauge
Keylight/HVAC changed to red
Relocated AUX input
Car is on stock suspension for now. Exterior is stock except for the STi scoop and the 20% tint on the rear windows.
Can't wait for next year to start doing stuff to it.
obx fuel rails
so i am new to the wrx tuning world and i jus got done boring my block and gettin some head work done but my biggest question is i ordered the obx fuel rails and noticed they dont have return lines and was wondering if i need anyting else to install them or will they just work fine as a direct bolt on? :confused::sadwave::confused:
You'll probably get more help if you create your own thread instead of posting in a modlist-only one ;)
Lets see if this fits on one post.. :tongue:
CGM 2005 WRX Wagon
Engine Specifications:
Stock EJ205
Engine Misc:
Gimmick Light Weight Crank Pulley
Camo’d Coolant Tank
Camo’d Alternator Cover
(Thanks Ryan…)
Turbocharger & Induction:
Helix RR500 20G TD06 8CM
CSS Performance FMIC
Tial 50mm BOV
Hallman RX Pro MBC
Fuel & Tuning
Open ECU Tune by Cleo @ Precision Tuning
Stock modded Injectors (825cc)
Walbro 255 Fuel Pump
Intake & Exhaust:
TXS Intake
Area1320 P&P Throttle Body
Gimmick Motorsports Turbo Inlet
Grimmspeed EWG Up-Pipe
Tial 38MM External Waste Gate
P&P Stock Manifolds
Ebay HKS Knock off Catless Downpipe
Greddy SP2 Catback Exhaust
Kartboy Exhaust Hangers
Drivetrain:
ACT Streetlight Clutch
ACT Streetlight Flywheel
Kartboy SS + Front & Rear Shifter Bushings
Kartboy Tranny Crossmember Bushings
TiC Klunk Killer
TiC Giuyngmyo Fender Cowl Braces
TiC Shifter Pivot Bushings
Suspension, wheels & tires:
Sedan Control Arms (+12mm)
Sedan Axles
BC Racing Coilovers
Whiteline Rear Strut Bar
Whiteline 27MM Front Sway bar
Whiteline 24MM Rear Sway Bar
Whiteline Front and Rear End Links
Whiteline Heavy Duty Rear Sway Mounts
Whiteline Rear Subframe Locks
TC Sportline Rear Control Arms and Lateral Links
17×9 Rota DTP With 245/40/17 Kumho Ecsta SPT
Stockers With Hankook W404 Snows
Brakes:
Hawk HPS FR + R Pads
Technafit SS Brake Lines
ATE Superblue Fluid
Interior:
JDM Hazard Button
Black Aluminum Kartboy Shift Knob
Huskymat Floor Liners
Defi BF Series Boost, Oil Pressure, and EGT Guages
ATI Clock Pod
Innovative LC-1 Wideband with Red Digital DB gauge
Autometer Single A Pillar Pod
Kenwood MP3 Deck
Exterior:
Tint
Black Rally Armor Mud Flaps
Grill Center Delete by Area1320
Rear fenders rolled by Area1320
Terry Body Hold Down Springs on front bumper
Sedan front bumper and fenders
Fog light covers
'05 CGM Subaru Impreza WRX
Engine:
OpenSource ECU Tune (Poohbear Stg II+ Map)
GrimmSpeed EBCS
VF43 Turbocharger (from '07 STi w/ 10k miles)
DeatschWerks 750cc Fuel Injectors
Walbro 255lph Fuel Pump with Install Kit
Perrin DDP
liteSPEC Titanium Cat. Back Exhaust
GrimmSpeed Exhaust Mani. CrossPipe, Ceramic Coated w/ GrimmSpeed Gaskets
GrimmSpeed Uppipe, Ceramic Coated w/ GrimmSpeeed Gaskets
Process West TMIC with PW Splitter and Silicone Hoses
Samco BPV hose (Black)
SPT Intake with Heatshield
GP Moto Intake Elbow
Intake Snorkus Delete / Removal
Perrin Turbo Inlet Pipe (Black)
Perrin Radiator Shroud (Black)
Forge Motorsports BPV (with 18 lb. spring)
Carbign Craft Carbon Fiber Pulley Cover
STi High Pressure Radiator Cap (1.3 bar)
Prodrive Oil Cap (Anthracite)
Mishimoto Magnetic Oil Drain Plug
93 Oct. Fuel
Drivetrain:
STi / SPT Factory Short Shift Kit
Kartboy Short Shifter Lever, Narrow
Kartboy Shifter Bushings, Front / Rear
TiC 5MT Lever Pivot Bushings, Narrow
Kartboy Pitch Stop
Redline 75w90 Gear Oil for Rear Diff
Suspension:
KYB Excel-G Struts (formerly known as GR-2s)
Mach V Lowering Springs (-1.0" F / -.75" R)
Perrin Adj. Front Swaybar, 22mm w/ Energy Suspension Bushings
Perrin Adj. Rear Swaybar Kit, 25mm w/ "Stout Mounts" & Energy Suspension Bushings
Kartboy Swaybar Endlinks, Front / Rear
Kartboy Rear Subframe Outrigger Bushings, Race
Kartboy Transmission Cross-member Bushings
Whiteline HD Steering Rack Bushings
Wheels/Tires:
Summer:
'04 STi BBS Wheels, Gold (17" x 7.5")
Undecided on tire brand & model but sized - (225/45R17)
McGard Spline Drive Lug Set, Black
Winter:
’03 JDM STi (Ver. 7) Wheels, Gold (17" x 7.5")
Sumitomo HTR A/S P01 W (225/45R17)
SOA / OEM Wheel Locks with OEM Lug Set
Brakes:
Perrin Master Cylinder Bracket
Front:
'04 STi Brembo Brake Calipers (Powder Coated, Black)
DBA 4000 Series Slotted Brake Rotors
StopTech Street Performance Brake Pads
Rear:
H6 Rear Brake Upgrade w/ Hardware Upgrade (G2 Caliper Paint, Black)
Exterior:
Genuine STi Hood Scoop with STi Splitter
Rally Armor Mudflaps, Basic (Black)
Perrin License Plate Delete, Front
Carbign Craft Carbon Fiber License Plate Frame, Rear
Pillar-Less Front Grille Mod
De-Badged Trunk Lid
Kartboy "Extra Long" Exhaust Hangers
Redline Tuning "QuickLIFT ELITE" Hood Struts
Oswald Performance Front Subframe
Oswald Performance Lightweight Undertray Mount Kit
Oswald Performance Lightweight Front Bumper Beam w/ RennenMetal Tow Hook
Oswald Performance Lightweight Rear Bumper Beam w/ RennenMetal Tow Hook
Interior:
'05 Prodrive STi Gauge Cluster, from UK STi (Reads in MPH!!)
Autometer CF Boost / Vac. Gauge in Autometer Gauge Cup
PLX M-250 Wideband A/F Gauge
Blitz TT w/ Blitz Harness
JDM Red Hazard Switch
STi Floor Mats (Black)
SOA Extended Armrest
Beatrush Delrin Shift Knob (Black)
JVC Arsenal KD-A615 Headunit w/ Harness
Electrical and Lighting:
ScoobyMods.com Fog Light Re-Wire Mod
DRLs Disabled
To Be Installed: :D :D
Kartboy Subrame Lock Bolts, Rear
TechnaFit SS Brake Lines, Front / Rear w/ Motul RBF 600 Brake Fluid
Genuine STi Side Splitters
"Uncle Scotty's Cocktail" Gear Oil Mix for Transmission
Removed / For Sale Items:
'05 Prodrive STi Gauge Cluster, from UK STi (Reads in MPH!!) -- $300.00
SPT Turbo Heat Shield -- $30.00
Quick Question
I am quite an avid WRX fan and starting to learn about cars in greater extent. I currently own a 2004 Subaru outback and sadly a WRX is out of the question for some years :( but I was wondering first what the big differences between the EJ255 and the EJ251 is? I was asking because I wanted to possibly start on making my outback STI spec. like the forester in my neighborhood.
EJ255 is not an STI motor. The only thing similar about them is layout and displacement.
I'd start a new thread.
'06 CGM Subaru Impreza WRX
<<Exterior>>
PIAA ion yellow fog light bulbs
Silvania Silverstar Ultra H7 headlight bulbs
<<Wheels / Tires>>
Black Rota Torque 17x8 +48 offset
Muteki black open end lug nuts
<<Brakes>>
Stoptech Slotted Rotors
Centric Posi-Quiet Ceramic Pads
<<Interior / Gauges>>
Lamco OEM boost gauge
JDM red hazard button
Plastidipped center console
Eddie Bauer infant to toddler carseat
Eddie Bauer window shades
<<Engine>>
Greddy T518Z /8cm^2 turbo
Perrin TMIC
DW 750cc injectors
Walbro 342 255lph fuel pump
RS*R Downpipe
Borla XR-1 Catback
SPT Heatshield
Grimmspeed AOS
<<Drivetrain>>
Exedy Stage 1 Clutch
OEM replacement flywheel
<<Suspension>>
Tanabe GF210 performance springs
Tokico D-Spec struts
AST 4100 Coilovers (not yet installed)
JRZ 8k/7k Springs (not yet installed)
Whiteline Com-C Top hats
Whiteline Anti-Lift Kit
Eibach camber bolts
2003 psm wrx
engine/perf-
ERZ catted DP
ERZ flex UP
ebay catback
k&n drop in
silencer delete
mishimoto rad and hoses
gimmick 170 thermostat
gtspec cooling plate
gm bcs
kito auto sport turbo heat shield
xpt Gm BCS stage 2 tune
kartboy exhaust hangers and battery tie down
exterior-
Koji headlamps
Diy yellow fogs
tinted tails
carbon sidemarkers
black "i" badge
painted black stock wheels (for now)
carbon bugeye mafia sticker
interior-
autometer tripple pilar
premium prosport boost and egt
innovate lc-1
brakes/susp/drivetrain-
Gruppe-s stage 1 brake upgrade (stainless lines,axis pads)
drilled and slotted F&R rotors
linlong 205/55/16 summer tires
more mods coming...(once i get a raise ha.
2005 Subaru WRX - Color: WRB
Subie Options:
All-Weather Package
Sunroof
Heated Seats
Momo Shift Knob
SPT Short Throw Kit
Engine/Performance:
evoIII-16G (or Big 16G, whatever it is...)
TurboXS TMIC
DW 750cc Injectors
Walbro 255L
Samco Inlet
APS 65mm CAI w/Amsoil Nano Dry Filter
Grimmspeed 3-Port BCS
NGK BKR7EIX Plugs
Helix Bellmouth 3" DP
SPT Catback
TurboXS UP
Forge BPV
AP v2, tuned by PDX
Driveline:
Group-N Transmission Mount
Torque Solutions Shifter Bushings
Suspension:
Prodrive Springs
Cusco Adjustable Rear Sway Bar
Wheels/Tires (Summer):
Enkei RPF1 17x8, Powdercoated Metallic Gray
Yokohama S.Drives (225/45/17)
Wheels/Tires (Winter):
2005 Stockies with Nexen 3000 All-Seasons
Interior/Electronics:
Omori Boost Gauge (green/red)
Stewart Warner GUS Digital Tach (red, in pillar)
Innovate LC-1 Wideband with Gauge (red, in pillar)
Clarion Double DIN MP3/CD
Exterior:
STi Scoop
STi Air Splitter
15% Tint all Windows, 5% Sunroof and Windshield Strip
STi Corner Splitters
JNA V-Limited Polyurethane Lip (much better than my previous replica of a replica that looked like buttcrack...)
Cleared Headlights
Grillcraft Lower
downpipe and stage 2 accessport
i installed my perrin downpipe today while at work, (if you have access to a lift just do it yourself don't pay someone else, it's not so bad) i set accessport to stage 2 it runs awesome, stock was 13.5 or so now its 18lbs.
2009 WRX prem.
spt chassis brace
spt strut brace
spt carbon fiber trim
spt grille no emblem
spt splitter
spt "i" trunk emblem
spt catback exhaust
PERRIN downpipe one piece
Cobb Accessport
Sti 5 spd. shift knob
HIDs 6000K
@Impreza2.0:
This is a modifications list thread, not a modification discussion. Place a link to your exact post (here) in your signature if you'd like to keep an up-to-date list and are having difficulty finding your post. If you'd like to discuss modifications you've done to your vehicle lately, we have a thread for that here.
This is the third time recently that you have been asked to refrain from discussion-style posts in this thread. I've linked you to the post which contains your mod list. Any other posts in this thread will be dealt with accordingly.
my03
Engine&Tranny
NEW ej20 shortblock(stock)
NEW Tranny(stock as well)
OBX 7cm 20g
DW 650cc injectors
Hallman MBC
Turbo XS TMIC and Y pipe
Turbo XS CAI
HKS SSQV
Perrin Turbo Inlet
Walbro 255lph(loud ass FP)
Ebay UP and DP
Apexi N1 CBE
Exedy stg2 Clutch kit
OEM Flywheel
Greddy Profec b spec2(only used for boost gauge)
Powerslot Rotors
Custom Tactrix tune done by Barnhearts Performance
5500rpm launch control
Anti lag Hack
no speed limiter with 8000rpm rev limiter
INTERIOR&EXTERIOR
FULLY covered blue&black tweed interior(everything but stock seats)
Custom Glassed center console(glassed and painted black
15% tint with sun visor
10000k HID headlights
Black housing headlights
Custom painted wheels(Black with blue pinstripe)
BFG Gforce ta kdw tires
Sti replica grill(did my best lol)
Your all welcome to check out all my pics on my myspace at
www.myspace.com/fastazzwrx
Im a noob at posting, but not to tuning
Engine&Tranny
OBX 7cm 20g
DW 650cc injectors
Hallman MBC
Turbo XS CAI
HKS SSQV
Perrin Turbo Inlet
Ebay UP and DP
Apexi N1 CBE
OEM Flywheel
Powerslot Rotors
Anti lag Hack
INTERIOR&EXTERIOR
^ You have a PM in regard to preventing the imminent destruction of your motor.
The 5,500 RPM LC won't bode well for his transmission either.
B/c of the 20g?
I'm guessing with only 650cc's... he's not running the 20G to full potential... if he has the 10% headroom that injectors should have... then I really doubt that the 20G will be flowing enough to destroy that block.
Just one man's opinion.
B/c of the 20g?
No, the 8,000 RPM redline on a stock engine and oiling system is what I really had in mind. He needs to reduce that back to stock, maybe 7,200 tops.
No, the 8,000 RPM redline is what I really had in mind.
totally missed that.
Cams, pistons, rods should be changed for such a high redline if I'm not mistaken... correct?
