I'm sure you've all seen this type of thread before. I'm on a mission of mercy here. My 2018 STi is for lack of better wording, dying a slow death. It's a stock motor with 28000 miles and I went stage 2 at approximately 25000 miles. Im running quality parts, installed by a reputable tuner. I'll list them below, and all parts were purchased new.
Accessport, NGK Spark Plugs, AEM fuel pump, 1050x injectors, cobb intake with box, Grimmspeed Gesi v2 downpipe, perrin catback, ebcs, and cobb stumble fix kit, among some other cosmetic and suspension bits.
Where I'm at is basically this, the car is throwing constant misfire codes, p0000, p0303, p0304, and the occasional AFR ratio imbalance. The engine surges on startup, and then simmers down. but the cel comes on, and it's relentless. I can't get past 50 miles after clearing codes before the engine surges again and throws a fit. My tuner has tried everything he can think of to try and help me through this mess I'm in. We've tried just about everything we can think of, checked the plugs, 2x compression test, checked the coils, checked the fuel pump and injectors, checked everything as far as I can tell.
Yesterday we even pulled the MAF out and he retuned me with a speed density, the car seems even more agitated now. WE thought maybe the MAF was acting up, still the same problem. I'll be contacting my tuner today to notify them of this.
I drive the car normally, not hard launches, ever. No beating on it, ever. A couple little pulls for fun here and there, it's my daily, and I love the car. I'm at a crossroad. Do I say to myself, " This was probably inevitable? These stock motors are prone to failure at any given moment when modified? Do I throw in a built motor and run into the same problem?". I'm stuck.
The car was always properly maintained when purchased new, and never gave me an ounce of trouble until I started throwing parts on. At one point I even went to a different tuner for a second opinion and retune and frankly, it wasn't as good as my original tuner. He tuned me super rich and the car was not running as smooth. So now Im just stressed out and feel like I'm out of options. If any of you were in my shoes, what would you do next? Do I build the motor? Pack it in and revert back to stock and part out?
I appreciate any and all feedback. Have a blessed day.
