Get the STI if you can possibly afford it. Even though the appearances maybe similiar, stock vs. stock, it's a completely different vehicle.
06 STI over a 06 WRX differences (est. price in quotes to add it later to a WRX, not including labor):
- Bigger turbo ($300-$900 depending on used vs new)
- Better engine (~$5k, maybe more) engine is almost the same, no need to upgrade, really
- Better brakes ($3-4K for a new Brembo BBK)yes, the Brembos are better but the '06 already comes with 4-pot fronts so better pads, fluid and lines go a long way to improve the stock brakes
- Stronger tranny ($2500 to $5000 depending on condition)
- DCCD adjustability (add cost to the above)
- Front/Rear LSD (???, but probably $1K)not really necessary unless you're planning on serious track time
- Improved Suspension (another $1K for sways and springs, but the STI still has a lot of better parts)if you spend $1k on sways and springs then you're shopping in the wrong place, for that kind of money you're close to coilovers which would put the STI suspension to shame
- Higher priced rims (wider too) ($600+ a piece new, $800-1200 used)no need to upgrade the wheels either, 225/45/17s fit just nicely, which is the stock STI size anyway
- Upgraded interior panels and seats ($800 to $1600 used)seats may be nice but otherwise useless
- Shift console trim ($75)short shifter - maybe, trim - not so much
- HID, adjustable headlights (expensive... $1000+ just for used)wouldn't call it a performance enhancer
- Intercooler spray system ($150)useless, if you're having bad enough heat soak issues then just upgrade your TMIC
- Larger Wing (could be free if you find someone to swap trunks, otherwise $700)this is a personal taste item, added downforce is only really relevant at too high speeds anyway
- Sidebody strakes ($300-400)not a performance adder
- Rear fender molding (can't find for WRX)not a performance adder
- STI Badging ($100)not a performance adder
- Underbody diffuser panels ($500, custom fit on WRX)adds a bit of high-speed stability but not really necessary
I know I'm missing a bunch other stuff...
Plus there is hidden costs (like tuning, supporting parts, attaching hardware, labor, etc)
