1 - 12 of 12 Posts
Super Moderator
That's pretty normal for cabin filters. It looks to be a charcoal filter and that would explain the color.
You can replace with any filter that fits, including another carbon or HEPA, and you can even add a dryer sheet so that the entire interior smells like fresh linen if you wish.
Discussion Starter · #5 ·
this was my air intake filter... a K&N. It took 3 washes and a scub with a toothbrush but I think it's good to go. Should have shared the after pic. Lol.
Agreed. I'd buy a $20 paper filter from any competent manufacturer before I'd use a K&N or any wet "high flow" filter.
Discussion Starter · #8 ·
Go buy a paper filter.
Why is this? Do you get more air through paper filter? It came on the car.
The point of a filter is to filter dirt. The air is adequate either way -- it's the dirt I'd worry about.
The scrub with the toothbrush has seriously compromised the filter. It has most likely disturbed the even weave of the fabric that determines the max particle size that can pass through. K&N recomends using cleaning agent and smoothly flowing water to clean the elements. You should replace it.
1 - 12 of 12 Posts
