1 - 10 of 10 Posts
Hi guys,
Been reading this forum for a while now and wanted to share some pictures of the 2006 WRX I just picked up. It has 103k miles on it and in great shape. Had the timing belt replaced at 94k miles, along with the belts, pullies, water pump and some other maintenance items.
I've had the car for less than a week and am pretty happy with the purchase. I had an RSX Type S before (now for sale) and this is quite a change. I really missed mid-range torque.
The previous owner installed a few very light mods:
SPT Intake
Goodridge Stainless Steel Brake Lines
Stoptech Slotted Rotors
Hawk HPS Pads
ATE Super Blue Brake Fluid
As of right now, the plans for the car are to throw on a set of snow tires (with either steelies or a used set of 16"s if I can find them), get a headunit and enjoy it.
I want to improve the shifter, steering feel and sound and need to do some research to figure out exactly which parts will work the best for me.
Here are some cell phone pics, I'll try to get some more with an actual camera sometime soon.
Very nice, and a nice set of mods. If you get 16's for winters make sure they clear your brakes as that can be somewhat tough to find
Welcome - that looks like a great wagon!
I'd say mod-wise, you seem to be pretty level-headed in terms of what you want. For shifter improvement, go to turninconcepts and check out their selection of shifter bushings and such. There are two front bushings, one rear, and one set in the linkage itself to replace, and if you want you can also get a short-shift lever. For steering feel, there's one bushing you can replace, then you're into more intense mods like steering rack replacement. EDIT: nearly forgot steering mods from the suspension side of things. HIGHLY recommended: get fender braces. From there, consider strut bars, and if you want to go so far, bigger swaybars (that last one should be done with caution - not too big on stock springs. It'll mostly help keep you flat, not so much turn-in and such.
Other mods I can suggest: if your brakes still feel a bit mushy, for about $100, you can get a master cylinder brace which will give you that last bit of support (gives great brake feel even for driving around town). It's good to see that all the other good brake mods are taken care of for you.
There are also some other bushings related to your drivetrain and suspension that you can replace - cheap bits of rubber that give you amazing results as long as you don't mind a NVH increase. Again, shop around TiC.
And, although it seems like you aren't thinking power right now, I can strongly suggest getting either a protune or a stage 1 map for your car. This will just help out normal things like drivability (fixes your DBW map, changes how your car goes into open loop fueling, and will give you a much beefier torque band - plus some extra power for your effort). Yeah, there's also stage 2 and such beyond that, but without that complication, a tune will help very much.
Anyway, for now, just focus on the tires/wheels and whatever is important to you. Those are just a few suggestions based on where you seem to be heading.
EDIT: And always, check out Unabomber's Manifesto for some more information about these and other great mods.
¯\_(ツ)_/¯
Great find! I have the exact same set of brake modifications, and it was a big improvement. Looks like you found a real gem.
That's what I'm finding. Unless I can find a set of used RS wheels (or some other 16 that fits), I'm probably gonna pick up a set of steelies from Tire Rack. It's tough to argue with $56 per wheel.
Thanks for the recommendations.
As tempted as I am to just start throwing money at parts, a wise friend of mine once told me to drive a car for a while and evaluate what really needs improvement before spending your hard earned money.
The stereo is a must. I drive 25k miles a year and have an hour long commute each way to work and back. Being able to use my ipod and have clear, crisp sound will pay off when im stuck in traffic and on the many trips out of state I take.
It's not the fastest car in the world, but I think power-wise the stock WRX is pretty good. Having torque again is a welcome change and it has plenty of passing power on the highway. A tune is in the plans for down the line, but there are other things to address before that.
I'll admit that I don't know too much on fender braces. Checked out a few reviews online and they seem like a great upgrade. Definitely worth some more research.
I'll be sure to check out the Unabomber's Manifesto.
Thanks! The brakes are great on this car. Pedal feel is great, the pads grab really well and there's no fade that I can feel.
Car overall is in great shape and I'm quite happy. The only thing that I'm not thrilled with is fuel consumption, i'm getting somewhere in the low 20s right now. I'm going to try and stay out of the boost while cruising on the highway and then just have to learn to deal with it I guess.
^^ This right here is probably about the wisest thing a new owner has ever said on here :p
Definitely drive it for a while. You'll feel what you need to fix (and the harder you drive it, the harder you'll need to mod it to keep up).
The Member
Your car looks great! Just wondering about the title of this thread. Did someone say that to you or are you surprised you purchased one?
The Fruit
When I went out in search of my wrx.. this is what I was looking for.. ended up with a 2010 hatch. I still think they should have stuck witht the hawk eye front end and updated the driveline like the 09+
Either way, wicked ride man.. looks great. Enjoy!
fyi, Check out Turninconcepts for the turning/shifting goodies. Give em a call if you have questions, they'll not steer you wrong. I'm not affiliated, just a happy customer.
that is a one nice and clean looking car!
Discussion Starter #10
Much appreciated, thanks. I'm just excited to finally have a car I'm excited about again. This car is a blast. I don't think I've been this excited for snow since I was in grade school.
Thanks! It was the reaction from one of my friends and frankly I was bit surprised myself. I've always liked wagons but never saw myself buying one.
I've gotten a lot of recommendations for Turninconcepts, it seems like those guys are really well liked/respected. Spent a good amount of time over the past few days going over their site and I need to contact them soon. I want to get some recommendations from them once I've done some more reading.
Thanks!
1 - 10 of 10 Posts
