Not a build thread exactly but a thread to contain everything going on with my car so I can keep questions organized and to the point, and people have an idea what I'm doing.
History on the car its a 2011 WRX I purchased in Feb 2015 with 75k. The car has only had one owner besides myself. When I got the car it had a 1" puck lift from Subtle 16" wheels and geolander AT's, it also had a problem with the drivers side window and its auto up and down, and a massive exhaust leak. Its currently back to stock suspension setup, the exhaust is repaired, but the window is still fubar. I'll update this first post at some point with any pictures I have but for now its time to get to the point.
As some of you have known I've had some various things going on with my car. I had gotten a few misfires so I decided to take the first step to solve that and change the plugs. Plugs solved the misfire events, and in general looked good. Green shows up in pictures taken with my camera phone, however the plugs have zero green tint to them in person. I didn't drive the car after this besides to do a test and find I had a boost leak somewhere.
I'll add what pictures I have of each event shortly. Right now this is a text based adventure.
Next I went on to the boost leak issue. I had found that a common place for boost leak to occur is around the intercooler boot. After that went tragically wrong and I got it repaired my low boost got better, but still shy of targets. I took some data logs and will post them here for you folks, and hopefully someone can stop in and lend a hand or idea whats going on. I don't have anywhere I can pull all the way to redline right now. The private road I was using no longer is available for me to run it out. I went as far as I could with them. If you need a longer harder pull I'll go find what I can.
Datalog 1 https://docs.google.com/spreadsheets/d/15bVAaYheHRJj9J2deP2iwuLDyg6GyB5XebGNmt5n9Ls/edit?usp=sharing
Datalog 2 https://docs.google.com/spreadsheets/d/1wqo0sewzpDumb82Sf4CTTcouw3XPwai1J-9iSQcgspY/edit?usp=sharing
The car as I bought it.
This is the exhaust that was leaking. It is fixed now thanks to a grimspeed adapter and proper gasketing.
This is the puck lift that was on the car when I purchased it.
I'm sure you all know what they look like stock so we can just ignore that. This is the rewired d6 connector for the power window. That wiring is wrong, don't trust it. I've got a simple diagram in another thread I started if you need it.
This is with the 1" lift factory wheels and snow tires just moments before the gentlemen at TiC fix the suspension, the exhaust, and put on my mpss
A picture of the plug post change. They all look the exact same. Any opinions on it I'll be glad to listen. I'm not a pro at reading them.
How my day started Friday morning.
And how I started it today.
