2005 Saab 9-2X Aero 128k Miles 5 Speed Part Out
Located in Fairmont WV or shipping isn't a problem just message me for a quote. If you want pictures of a certain part or interested in something not listed just ask.
Engine & Drivetrain
EJ257 Short Block (Spun Rod Bearing) $400
EJ205 Cylinder Heads - Supertech Valves, Retainers and Springs (30k miles) $800
Cosworth Camshafts (30k miles) $600
OEM Cam Gears $50
STi Cat Back Exhaust $200
Invidia N1 Street Cat Back Exhaust $200
Catless Downpipe (Slip on style/No flange for cat back) $75
ACL Streetlite Flywheel $100
Walbro 255 LPH Fuel Pump $50
800cc Injectors $200
Intake Manifold $100
Throttle Body $50
Top Feed OEM TGV Deletes $100
Coil Packs $100
Radiator Fans $25 each
Coolant Expansion Tank $35
Coolant Crossover Pipe $35
5 Speed Transmission $500
Shifter Assembly $50
Rear Differential $100
Axles $75
Driveshaft $100
Engine Crossmember $100
Transmission Crossmember $50
Rear Crossmember $100
Rear Differential "T" Crossmember $100
Alternator $100
STi Steering Rack #34110FE580 $250
Power Steering Reservoir $25
AC Compressor $100
AC Lines $25+
AC Condenser $50
Washer Fluid Tank $25
Clutch Master Cylinder $35
Clutch Slave Cylinder $30
Clutch Fork $20
Clutch Fork Rod $20
Wiper Motor & Linkage $40
Purge Valve $20
Purge Solenoid $20
Charcoal Canister $40
Cruise Control Actuator $40
Rear O2 Sensor $35
Front 02 Sensor $50
Top Feed Fuel Rails $50
Fuel Pump Controller $50
Fuel Pump Hanger $50
OEM Boost Controller $20
Boost Controller Bracket $10
Outer Timing Covers $15
Killer B Radiator Shroud SOLD
Killer B Alternator Cover SOLD
Group N Tranny Mount SOLD
Group N Pitch Mount SOLD
Group N Motor Mounts SOLD
PTP Turbo Blanket Lava SOLD
Invidia Catless Downpipe SOLD
STi TMIC with Mishimoto Hose SOLD
Cusco Turbo Heat Shield SOLD
Cobb AP v2 001 Unmarried (02-05 WRX) SOLD
ARP Head Stud Kit SOLD
Gimmick Inlet SOLD
Tomioka TD06-20G SOLD
Tomei JDM UEL Header & Uppipe SOLD
Radiator SOLD
Mass Air Flow SOLD
Power Steering Pump SOLD
Power Steering Lines SOLD
Power Steering Pump Bracket SOLD
Engine Harness SOLD
Bulkhead Harness SOLD
ECU SOLD
Perrin Ram Air Intake SOLD
Inner Timing Covers SOLD
Suspension, Wheels, Tires & Brakes
BC Coilovers $500
Rota DPT 17x8" +48 5x100 & 5x114 Bronze $400
Saab Enkei 16x6.5" +55 5x100 Silver $400
Subaru Baja Wheels 16x6.5 +48 with 215/65 Winter Tires $300
Adjustable Front Lateral Links & OEM Rears $100
Knuckles $75
Control Arms $50
Trailing Arms $40
Front Calipers $75
Front Rotors $25
Rear Calipers $50
Rear Rotors $25
ABS Sensors $25
Brake Master Cylinder $25
Brake Booster $50
Proportioning Valve $20
Kartboy Front & Rear Endlinks SOLD
Cobb 25mm Front Sway Bar SOLD
Cobb 25mm Adjustable Rear Sway Bar SOLD
Cobb Rear Sway Bar Mounts SOLD
ABS Module SOLD
Exterior
Taillights $75
Hood $150
Scoop $50
Doors $150
Mirrors $50
Fenders $100
Front Bumper $200
Front Bumper Beam $50
Rear Bumper $200
Rear Bumper Beam $50
Hatch $200
Side Skirts $100
Chassis $500
WRX Wagon Roof Rails $75
Thule Fairing #770055 $50
Grille $50
Gas Lid $20
Wiper Arms $30
Rear Wiper Assembly $30
Trim & Weather Stripping $10+
Fog Light Surrounds SOLD
Fog Lights SOLD
Tow Hook Cover SOLD
Headlights SOLD
WRX Wagon Crossbars SOLD
Interior
06 WRX Front Seats $400
06 WRX Rear Seats $100
Perrin Adjustable Short Shifter $50
Ostrich Skin Door Cards $100
OEM Door Cards $100
Carpet $100
Dash $100
Glovebox $50
Gauge Cluster 128k Miles $150
ProSport 52mm Oil Pressure Gauge Green/White (New) $40
OEM Front Speakers $25
Infinity Bass Link 200 watts 10" Subwoofer $150
Cluster Surround $20
Steering Column $75
Ignition with Key $50
HVAC Controls $40
Window Motor $25
Door Harness $25
Headlight Switch $25
Wiper Switch $25
Fog Light Switch $10
Hazard Switch $10
Mirror Switch $15
Master Switch $35
Window Switch $10
E-Brake Handle $30
Clock & Trim $45
Cup Holder $20
Rear View Mirror $25
Map Light $25
Dome Light $20
Rear Hatch Light $20
Visors $40
Clutch, Brake & Gas Pedals SOLD
Shifter Bezel & Boot SOLD
Heated Seat Switches SOLD
Pioneer Double Din Head Unit AVH-P4200DVD SOLD
Composite Shift Knob SOLD
Center Console SOLD
Radio/HVAC Trim SOLD
Ebrake SOLD
Boston Acoustic Rear Door Speakers With Adapters SOLD
Engine & Drivetrain
OEM Cam Gears $50
Throttle Body $50
Coil Packs $100
Axles $75
Driveshaft $100
Alternator $100
AC Compressor $100
AC Lines $25+
AC Condenser $50
Clutch Fork $20
Clutch Fork Rod $20
Purge Valve $20
Purge Solenoid $20
Rear O2 Sensor $35
Front 02 Sensor $50
Gimmick Inlet SOLD
Radiator SOLD
Mass Air Flow SOLD
Engine Harness SOLD
ECU SOLD
BC Coilovers $500
Knuckles $75
Control Arms $50
Trailing Arms $40
Front Calipers $75
Front Rotors $25
Rear Calipers $50
Rear Rotors $25
ABS Sensors $25
Brake Booster $50
ABS Module SOLD
Exterior
Taillights $75
Hood $150
Scoop $50
Doors $150
Mirrors $50
Fenders $100
Front Bumper $200
Rear Bumper $200
Hatch $200
Side Skirts $100
Chassis $500
Grille $50
Gas Lid $20
Wiper Arms $30
Fog Lights SOLD
Tow Hook Cover SOLD
Headlights SOLD
Interior
OEM Door Cards $100
Carpet $100
Dash $100
Glovebox $50
Steering Column $75
HVAC Controls $40
Window Motor $25
Door Harness $25
Wiper Switch $25
Hazard Switch $10
Mirror Switch $15
Master Switch $35
Window Switch $10
E-Brake Handle $30
Clock & Trim $45
Cup Holder $20
Map Light $25
Dome Light $20
Visors $40
Center Console SOLD
Ebrake SOLD
