1 - 2 of 2 Posts
Excellent performance, easy to install as it doesn't require a harness. Probably the best ECU option for Subaru drivers, great value for money.
MoTeC M800 Plug-In ECUs are fully programmable, direct replacements for factory ECUs on a select number of popular vehicle models. Based on the M800, they control the latest automotive advances such as continuously variable camshaft timing and drive by wire throttle.
Complete with an OEM connector, M800 Plug-Ins are convenient and cost effective to install because they eliminate the need to rewire the vehicle. They simply plug into the factory wiring harness using the original sensors, ignition modules and fuel system. The units are built to operate with saturated drive fuel injectors.
Suitable for WRX and STi: most models from 1999 - 2008
$2.5k Negotiable
I'm looking to let this ECU go asap, so I'm open to any offer as long as it's reasonable. :)
Interested parties SMS 90689412, thanks.
1 - 2 of 2 Posts
