1 - 5 of 5 Posts
My trunk latch near the driver seat will no longer open my trunk. Yes, I can open the trunk with the key, just not the interior latch. Any ideas how to fix this? Is this a common problem with WRX?
I had this problem about a month or two ago, and I thought something was wrong, but it really wasn't. Check your trunk latch...there's a tab that should be slid down, but it may be in the up position on your trunk. I didn't bother looking it up in the manual, but I'm pretty sure it's a security feature so that someone who is inside your car can't just open the back from the latch. Slide it down and it should work just fine.
Moderating U!
Verdugo is right. I had the same problem right there at the dealer when I was buying the car. There is a safety feature latch that you can use so the trunk can not be opened from inside the car. Only with the key at the trunk.
Kurlee Daddee
(THE ORIGINAL)
1 - 5 of 5 Posts
