21 - 26 of 26 Posts
ok heres some info for you
02-03 uses a smaller 3rd and 2nd gear
late 03 and 05 got a upgraded 3rd gear
02-05 transmissions especially the wrx trannies all mate wiht no issues the only diff is the 02-early 04 has axle stubs coming out of the transmission
late 04 and up doesnt and you need male axles
now all of the transmission will mate with your block. rs rs sport wrx and sti will all mate doesnt matter if its a 2.5 or 2.0 the bell housing is the same.. thats why you can swap a sti tranmission into a 02 wrx from any year.
you can do a ppg gear but expect to pay a crap ton of money. you can do a 06-7sti transmission swap which is cheaper and the rear diff doesnt need to be changed but you need a automatic driveshaft and the axle stubs
there are alot of tutorials just pm me for info..
also i have done all of the above swaps on diff wrxs and have done alot of research on swaps
I just picked up a 2006 wrx transmission with LGT gears, rear diff to match, axles, clutch, but it has the push style going towards the fire wall where as my oem 2004 wrx has the pull style. With all the parts I think it’s a direst swap over either way, just use the clutch from the 2006. Is there anything I should be aware of? Will my 2004 wrx oem drive shaft work for the new 2006 wrx transmission and diff.
Can a 2010 STI swap go into a 2002 bugeye WRX
Subaru limited crew
Hey man I'm dealing with this swop and its a 02 rs with a 2010 wrx trans iner spline is 25 outer is 27 but most factory outer spline length aren't long enough??
Hey man what’s up! I have a 03wrx and the tranny shit out on me. Can I use this 04 I found a couple hours away?
21 - 26 of 26 Posts
