BUILD LOG:
WRX-maniac's 2012 STi Limited Sedan
The Story:
I traded in my 2011 WRX for this STi in June of 2016. It has been my dream to own an STI since I could drive. With finally owning one, my goals are to eventually end up making this car my weekend warrior/track car. Although I will have to DD it for a few years. My main focus will be making good horsepower, while building up the suspension and drivetrain components at the same time. Overall I just want this car to be everything I have always envisioned it to me in my mind, and have fun while doing it. Hope you enjoy!
The Car:
2012 Subaru STi Limited sedan
World Rally Blue
Chassis Mileage : 70,102
Built motor mileage : 12,013
FULLY BUILT, ROTATED TURBO GOODNESS/ 3rd Place car at 2022 Import Nationals in Carlisle PA
710whp @40psi on E85
582whp and 518wtrq @ 28psi on pump 93
Current Modifications:
Short block:
-V4 closed deck from Outfront Motorsports
-Manley platinum series forged pistons (oversized 99.75)
-Manley turbo tuff I-beam rods
-ACL main and rod bearings
-ARP 1/2 inch head studs
-new STi nitrate treated crankshaft
-Secondary air pump delete w/Andrewtech block off plates
Oiling Components:
-Killer B ultimate pick up
-Killer B oil pan and baffle
-New STi 11mm oil pump
Heads:
-Kelford 272 camshafts
-Supertech Dual Valve Springs set
-Supertech Spring Seat Locatorset
-Supertech Titanium Retainer set
-Multi-Angle valve job
-Adjusting valve clearance
-Disassemble and Assemble Cylinder heads (includes valve stem seal replacement)
-Deck cylinder heads
Engine/Exhaust/Performance Mods:
-KillerB Holy Header
-Turboxs rotated turbo kit
-Garrett GTX3582r gen 2 turbo
-ETS 4 inch core FMIC w/ powder coated wrinkle black piping
-Tial 38mm external wastegate
-Tial Q 50mm bov
-Speed density sensor
-MAF sensor (to read air intake temps only)
-ETS catback (with mufflers, no resonator)
-Cobb Accessport V3
-Aeromotive A1000 manual fuel pressure regulator
-Cobb fuel pressure sensor
-Grimmspeed 3 port ebcs
-ID1700cc injectors
-Radium dual pump hanger with dual walbro 450's
-IAG AOS (comp. series) in
Red
-IAG TGV deletes in
Black
-IAG v3 fuel rails in
Red w/ IAG fuel lines
-Cobb 4-BAR map sensor
-Cobb flex fuel sensor
-Fuildampr dampening crank pulley
-Koyo Radiator with GS radiator hoses
-DEI turbo blanket
Ignition Upgrades:
-NGK one step colder plugs
-OTL Performance street series coil packs
Brakes-Current setup:
-GoodRidge Gstop Stainless steel brake lines
-Motul 5.1 brake fluid
-DBA 4000 series drilled and slotted rotors
-Hawk HPS pads
Exterior/Aesthetic:
-Perrin 2 inch shorty antenna w/ navigation
-IAG front license plate delete plate
-Debadged trunk
-Grimmspeed license plate relocater
-Vinyl overlays for tail lights. Red blinker overlay and smoked reverse light
-Subaru JDM R205 Black Side Ornaments
-20% window tint, plus windshield strip
-Gloss black window chrome deletes
-JNA Performance C-Style polyurethane front lip
-APR Carbon Fiber front wind splitter
-Flex Fuel badge
-Downforce solutions v2 rear diffuser
-Downforce solutions side skirt extensions
-OLM RS style gurney flap in gloss black
-Gloss black subaru emblems with white stars
-Verus Engineering hood scoop block off plate
-Verus Engineering hood louvers
Drivetrain/Transmission/Suspension:
-ACT Xtreme Duty Performance Street clutch kit and new FHI oem flywheel
-Kartboy short throw shifter + bushing kit
-Turn in Concepts transmission crossmember bushings
-Turn in Concepts Shifter Pivot bushings
-Group N Transmission mount
-Perrin Pitch Stop Mount
-Cygnus Performance X-1 coilovers. Motorsport edition (9k/9k)
-IAG competition series engine mounts (90A durometer bushings)
-2015+ STi steering rack and pinion
-Whiteline Steering Rack bushings
=Cusco rear strut tower brace
Engine bay dress-up:
-Perrin Rad Shroud in
Red
-Perrin pulley cover in
Red
-Perrin ebcs cover in
Red
-Perrin fender shrouds in Red
-Perrin battery tie down in Black
-Billetworkz Zero Series Black engine bay caps
Interior:
-JBL club 6520 front door speakers
-SMY Dual gauge cluster
-AEM UEGO wideband AFR gauge
-AEM oil pressure gauge
-SMY 52mm accessport mount
-SOLiDMods 52mm vent pod
-Autostyled Black Leather shift boot w/ red stitching for short shifter
-Autostyled Black Leather E-brake boot w/ red stitching
-Billetworkz weighted shift knob
-FactionFab carbon fiber and leather "D" shaped steering wheel
-Braum Elite-S Racing seats
-Idoing head unit
Wheels and Tires:
-Enkei PF09 in vanquish white (18x9.5 +40)
-BFGoodrich G-Force Sport Comp 2 tires (235/40/18)
The Future:
Engine/Exhaust/Performance mods:
-Process West reverse/track intake manifold
-Whiteline rear diff positive power kit inserts
-Whiteline rear subframe inserts
-Whiteline roll center kit
-Cusco sway bars and endlinks
-Cusco front strut tower bar
