1 - 3 of 3 Posts
ClubWRX.net Vendor
2002 – 2004 Subaru WRX exc. STI
Hello everyone. I have 10 sets of rotors available for the 2002 – 2004 Subaru WRX. The rotors can either be drilled only, slotted only, dimpled, or combination of either. The prices and dimensions of the rotors are as follow:
Front X-Drilled Slotted Rotor = $80.00/ per rotor
-Outside Diameter = 294mm
-Height = 56mm
-Bolt Pattern = 5-100mm
Rear X-Drilled Slotted Rotor = $70.00/ per rotor
-Outside Diameter = 265.5mm
-Height = 65.7 mm
Contact: Dan
Phone: 714-554-6162
Email: [email protected]
The 1st three buyers who purchase both the front and rear rotors will be given a discount of $25.00. The reason is that I will need feedback from all of you regarding the quality of the rotors to other members.
What about the warranty? No worries. Slam on the brakes as hard as you want. Try cracking them if possible. All rotors will have 90 days full replacement warranty. We stand behind our products and will take good care of our customers.
All R1 Concepts Rotors are certified to meet QS and ISO Quality System Standards. All rotors are manufactured to OE specifications using the same process as the factory does. Black E-Coating is applied to the rotors for a custom look and rust protection.
1 - 3 of 3 Posts
