1 - 10 of 10 Posts
Hey all,
A WRX is going to be in my future for sure, but I had a few questions:
I can't seem to find a concrete answer, is a stage 2 protuned car safe with the CVT? Assuming I've gone to the effort of a CVT cooler
And in general what made the CVT owners choose that trans? The car would be my daily, lightly modded and occasional autocross
I Drink & I Know Things
I just had my ‘16 CVT tuned. There is a limit based on TQ and heat. I recommend the F1 Motorsports cooler over the Mishimoto. It adds about 2 extra qts of trans oil.
Mine is a daily driver as well. Bring it to someone with plenty of CVT experience. Not easy to find. I can’t speak for reliability yet, but you’ll want to tune it fairly conservatively. Mine is at 278 WHP / 275 WTQ. I know there is a nice build on Nasioc (Bellitopen) that is a higher HP/TQ example and has run well for several years. Feel free to check out my build for all the parts installed or PM for any other questions.
Discussion Starter · #3 ·
My next question for CVT owners: in sport sharp, when downshifting via paddles, does the engine blip the throttle a little? I could swear I heard it when I test drove one
Sent from my Pixel 2 using Tapatalk
Super Moderator
It shouldn’t as the transmission is constantly engaged.
S# simulates 8 gears vs S which simulates 6 gears. S# will also do some rev matching under moderate to heavy braking. It’s the most obvious ‘shifting’ of the 3 modes. It does have a simulated type blipping I guess you could say.
Edit: I would also add I didn’t use S# mode much until after my tune. It’s less clumsy now & more enjoyable. Likely from the more linear power.
Super Moderator
Do you have to be wringing it out to see that? The one I test drove didn’t do that at all. Does it unlock the torque convertor or just an artifact from the simulated gear change?
Discussion Starter · #8 ·
Do you mind me asking what is keeping you from a manual transmission ?
I've been driving stick since I was 16, and while I really enjoy it, for a car I'll be driving to work every day and taking on road trips, a auto sounds more pleasant in the long run
No, not really...just moderate acceleration. I’m not positive HOW it works...suspect it’s the simulated gear change.
EDIT: adding to that...more progressive acceleration rather than just mashing it.
1 - 10 of 10 Posts
