1 - 9 of 9 Posts
WRX 2011 Not hitting target boost
After installing the Cobb SF intake and their AP I was able to see that i'm not reaching boost target( getting 15psi). Reflashed to the HWG and it got bit better, i'm hitting the 16psi tapering down 11's. still not reaching Cobb's target boost. after watching the data logs i can see big boost lag (boost hits after 3k). so i was wondering what can cause it and if there is something wrong with the car?
I'm using Cobb's stage 1 Sf intake 91 HWG.
https://drive.google.com/drive/folders/1xO27_VPifVTW5fVv7NX94v1rz3uzFbNi?usp=sharing
Æternum
Where do you live?
Altitude plays a big part in boost targets. Temperature too.
EDIT:
Seems to me you are hitting target boost with the HWG map. Per the map notes:
91 octane (95 RON) Boost Targets: ~16.5psi peak boost pressure tapering down to ~11.5psi by the 6700RPM redline, +/- 1.0psi
Discussion Starter · #3 ·
Thank you for taking the time and going over the data logs. I live in the Bay Area, CA.
Can I use the HWG map for daily driving?
Another thing I saw that I hit boost pretty late comparing others data logs. Is it normal?
Thanks again! And sorry for the noob questions I’m pretty new to a turbo car
Super Moderator
Yes. That's what it's there for. Just make sure you are using the 91 acn tune
Discussion Starter · #5 ·
I just realized on the Cobb website it says "ACN91/CAD94" is for CA.
I'm running the "91 oct / 95 oct" . Is there any difference with the ACN91/CAD94? and can it cause damage running couple days with this map?
XJman Thank you for paying attention!
Email Cobb with your location and the fuel specs you buy and see what they say. They should support their product.
Discussion Starter · #7 ·
Changed the maps to ACN91 NWG ~ was getting around 14psi
changed to HWG and got closer to boost target ~ 15+ psi
https://drive.google.com/open?id=1gdb-BciRbrecrtCpfZoE12hGUq42ijge
this is from the last run.
Sent everything to Cobb . Thank you for the helpers!
Super Moderator
Æternum
The 91 acn tune has lower targets to keep the engine from knocking if I recall correctly.
You'd be right. Per the map notes:
ACN91 octane Boost Targets: ~16.0psi peak boost pressure tapering down to ~11.0psi by the 6700RPM redline, +/- 1.0psi
1 - 9 of 9 Posts
