Ok, I'm not a newbie to rebuilding engines... if they are the V or inline versions. Never rebuilt a flat 4 and can't imagine it's much different.
My step son spun 2 rod bearings, 1 and 4. Not much for metal shavings throughout that I could see upon initial inspection but that only included the bottom of the pan, and the oil pick up screen.
The engine has not been pulled yet and I still have to look at and/or measure the cylinder walls, pistons, rings, ring clearances, cranks shaft journals, connecting rods, etc.
I know we can reuse headbolts and block through bolts, etc.
So here is my question, assuming I measure and tolerences come back as still within specs, is there anything aside from rod bearings, main bearings, and a complete gasket set that I should consider replacing on this motor?
It has +/-76,000 miles on it. He has limited funds to work with. Again, assuming much without pulling the engine, I can pull it, boil it, turn the crank, get oversized bearings, replace all gaskets, and update the oil pickup for about $800.
Minumum on a shortblock that I've found is about $1650 and that doesn't include a master gasket set for $250ish plus an upgraded pickup for about the same.
Any thoughts would be much appreciated.
Thank you in advance,
Michael
Michael
