1 - 4 of 4 Posts
Hey guys....
i have a t3/t4 50 trim set up on my ej20 running with a turboxs man boost controller and tuned with ecutek.
Its pretty laggy and i turned the boost up one day for fun, but when i ran it in every gear it doest go past the .12 Mpa mark on my stock boost gauge.....12 Mpa is around 17 psi of boost
Im thinking that either my boost gauge is broken or i have a leak somewhere.....
the other day i did put back on my stock exhaust since i got a ticket for my perrin....
not too sure how it was boosting then
What do you guys think the problem may be?
anything would be great...thanks
If the only thing different is that you swapped to the stock exhaust, (that has to be WAY, WAY, restrictive), then take it off and see if that solves it.
ill check the bypass valve.....
this issue keeps bugging me more and more everyday......hopefully i can figure this out....
thanks for the comments guys
1 - 4 of 4 Posts
