So my plan is since my current OEM wheels are pretty trashed, go throw some winter tires on them and get some new wheels with summer tires. Now the question is can I swap sets and be good or is there some programming needed for the tpms?
From the Subaru manual of a 2022, it read like they should automatically set themselves up.I thought the latest gen would sync to the tpms after some miles, if it's the correct tpms on all tires? But maybe I just dreamed that.
I appreciate the information. Thank you.From the Subaru manual of a 2022, it read like they should automatically set themselves up.
TPMS valve self-registration
When the wheels are replaced (such as when installing snow tires) or when a new TPMS valve is mounted on a new installed wheel,
you will need to perform TPMS valve self-registration. Refer to the following procedure to perform TPMS valve self- registration.
1. Install the wheels with TPMS valves on the vehicle.
2. Adjust the tire pressure to the specified value. For information about the specified value of the tire pressure, refer to “Tires” �P468.
3. Drive at speeds above 25 mph (40 km/h) for at least 4 miles (6 km) or until the low tire pressure warning light turns off.
Getting the 2022 sensors has been difficult and reported few and far off.Thats good news
